65 L78 396 425 Hp Original Holley 3124 Carb
http://img260.imageshack.us/img260/1...arb18uz.th.jpg
http://img259.imageshack.us/img259/3...arb24us.th.jpg http://motors.search.ebay.com/_W0QQsassZrjjudge 65 CORVETTE HOLLEY 3124 CARBURETOR ORIGINAL L78 396 425 HORSEPOWER 780 CFM HOLLEY 4 BBL GM factory installed ORIGINAL off an original 1965 396 425 Horsepower Vette. This carb was recently treated to a concourse restoration and set up on a wet flow bench with 0 miles on it and is MINT! The numbers on the carb are as follows: GM factory part# 3868826 List number 3124 Date code 3rd week of March, 1965! It still retains the factory installed peanut or acorn float bowls. It also retains the originally installed correct 5583 and 4519 primary and secondary metering blocks! Item number: 4634281441 Mention you saw it on this fine web site and I will make a contribution to the Corvette Forum coffers. Thank you, Rob. |
Hi Kevin, Hope all is well. It is NOT painted gold. It is the correct gold cad plating done by www.customrebuiltcarbs.com 732-356-4333 ask for Phil, he is one of the best. All the best, Rob.
How Much?
Need 5583. Metering block
