Dana 36 Fluid change
Got the Helms manual, got 75W-90 syn gear oil.
Based on a minimal observation of the rear end, how the hades do you drain the fluid? I see the diff carrier cover bolts, do I loosen all the carrier bolts and drain? Or does it need a more in depth job? |
Like this: C4 Guru - Changing Differential Fluid
