Maybe Orlando bound, need a few tips
I have a possible job opportunity in Orlando. I'll be commuting there and will need a place to stay. In the airline business we call it a crash pad (a place to stay with usually a few other people to split the costs). I'll need a place near the airport. Any ideas or suggestions?
Thanks guys. |
Theres a TON of cheap apts and condos around that way. (The airport can be LOUD)
I live across town from there, and dont know the complex's by name, but the major residentals are a little off the airport main drag. If you are looking at mapquest... The main road going into the airport is SEMERON (aka 436), but thats mostly commercial. The off-roads around that area with the cheap residential are called, PERSHING, GATLIN, and GOLDENROD. I know its not much help, but its a start. PM me if you need any local help, and good luck with the move. |
I saw a bunch of new residential towers going up when I drove through yesterday...
The best place would be the Conway area. There are multiples of apartments on Conway Road, which is a 10-20 minute commute to the airport, depending on time of day, etc. Also has all the conviences close at hand. I worked for the airlines and transfered here in 76. Moved to the area due to the proximity to the airport, stayed because it is a great area. 15 minutes to downtown, 45 minutes to the coast, hour or so to Tampa area, 20-30 minutes to the theme parks. Let me know if there is anything else I can answer.
Thanks guys. :cheers: Chris |
Don't you just love this forum? Thanks for the help. I'll let you know how the interview goes. Hopefully, I'll be getting to know some of you Corvette guys in the area.
