chassis flex fix?
the car twists more than i like, (86 vert)
how do you make the chassis more stiff without making the ride more stiff? elementary knowledge level please. |
Buy a RD Racing cross frame problem solved.
C4 Verts should have an X-brace from the factory. The factory brace not only attaches to the corners of the frame, it also is bolted to the floor pan in (IIRC) 6 places; 3 bolts go thru the floor pan on each brace.
I've been fighting this to...These are the things I have done all of which has helped
Lowered car larger sway bars new bushings camber brace new shocks |
I missed the Vert part.You can modify your brace by boxing it in with 1/8 X2 in. plate welded to it and it will strengthen it.
Camber Brace and Cross-bar solved my flexing problem.
Camber brace would be the first step, there are rollbars available from other places than RD and that would be the 2nd step.
Larger sway bars would also help somewhat. |
http://www.r-dracing.com/camberbrace2.jpg
http://www.r-dracing.com/cbv1.JPG http://www.r-dracing.com/cross-frame_001.jpg Good information guys. Thanks! |
