Driving a US Corvette in Europe
I am currently living in the US and I drive a C5. Since I might go back to Europe (Germany) soon and since I don’t want to be Vette-less I wonder what my options are.
1. I could take my 2001 C5 to Europe and try to register it there. The German inspection is very strict. What would I have to modify to pass? To my understanding, in Germany cars are not allowed to use the same lights for the turn and break signals. Would I need to convert to Euro style tail lights or could I get an exempt and drive the car as it is? Thanks, Robert2. I could buy a (new) C6 in the US. Would I be able to get the Euro version with different tail lights, FM radio (different so-called emphasis)? Would the navigation system work in Europe? Would the factory warranty be in effect in Germany? Can I get something as an extended warranty in Germany? 3. Of course buying the car in Germany would be least troublesome but probably also the most expensive option with € 53.836,21 (about US$ 64,600) + tax for the C6 Coupe basic MN6 version. This number is to be compared with US$ 44,900 + tax in the US. Did a forum member buy a C6 in the US and took it to Europe? |
Robert,
I shipped my 05 to the UK and drove it in Europe over several years. No problems. Must indeed be converted to European specs and this does include changing the tail lights. Not difficult or expensive and was done by Vauxhall (GM in Europe with trained Corvette mechanics). Now I am back in the US,have a C6, and would say that it is somewhat better suited for Europe than the C5, if this makes a difference in your decision. Good luck! |
Take yours with you, buying a car in Europe is expensive.
Drop SteveGermany a PM. He could give you a good idea of the requirements. ;)
Are you going over as a Fed employee affiliated with the military? If so, you can register your vehicle with the military and not have to worry about the European specs. Actually though, the European specs are not that much different than US and only require relatively minor changes, depending on what country you will register the vehicle in.
Yep, Only the rear lights and a side turning signal (front fender) will be required... and I believe the DRL's have to be disabled...
The C6 Navigation works perfectly in Europe. When I went to the 24 Hours of LeMans last year with the C5/C6 Registry, three cars had Navigation. All that was needed was the European Navigation disc. No other changes were necessary. It sure made travel from one city to another a whole lot easier.
One vote for buying a C6 here and shipping it over. Frank :seeya |
The C6 Navigation works perfectly in Europe. When I went to the 24 Hours of LeMans last year with the C5/C6 Registry, three cars had Navigation. All that was needed was the European Navigation disc. No other changes were necessary. It sure made travel from one city to another a whole lot easier. Can you tell me through what method you shipped it over and how much it cost along with any other expenses in bringing your Vette over? I've had a similar idea to bring my ride over for a little bahn and Nurburgring running but never knew someone who did. Thanks! |
Originally Posted by Another Yellow
I was only the passenger, and at the last minute. I'll ask the driver and get some info for you. :cheers:
I shipped my 05 to the UK and drove it in Europe over several years. |
I think I've figured it out: You meant to write C5 instead of 05.
I am associated with the Military so I did not have to convert the car to German standards. You can get an international plate but that is only good for a month (allows you to buy a US spec car and drive it in Europe).
I do not think that I would try to convert the car to German standards - you will need headlight washers and most likely new headlights in addition to the side markers. If something goes wrong with the car there could be a problem getting warranty service as well. German Corvettes I put mine in a container but I would just use a roll on roll off ship if I had it to do over again. |
Corvette in Europe
We shipped our Corvettes over last June and also several years before that. I'll be glad to answer any questions if you send me a PM
JM |
:lurk:
Thanks to all who replied.
Originally Posted by silvertc6
Robert,
I do not think that I would try to convert the car to German standards - you will need headlight washers and most likely new headlights in addition to the side markers. If something goes wrong with the car there could be a problem getting warranty service as well. I put mine in a container but I would just use a roll on roll off ship if I had it to do over again. Could I get warranty service in Europe for a C6 that I bought in the US? |
It very easy to get the car converted to euro spec & you don't need to convert the headlamps to have washers on them.
Most people bring them to England & they pass the SVA test to make them legal in europe The German test is a lot more changes than than the UK need pass the car in the Uk & it can be driven legal anywhere in Europe. it will cost about $2000 for everything in the Uk & no the warrranty would be no good in Europe but Sat nav works. I live in England & own a C6 :flag: |
I didn't know that in Germany cars are required to have headlight washers. This wasn't the case when I still lived there, i.e. in 2000.
You might need to change/alter the unit tho, because you need a "city-light" wich is a small bulb. But maybe there are other options... http://members.home.nl/corvettemania...-c6-europe.JPG |
