Snap-On Phneumatic Car Lift (anyone?)
Howdy,
Saw a very cool looking Snap-On phneumatic car lift in someone's photo galley here recently. (Portable Scissor-type on wheels). Didn't appear to lift more than perhaps 3 or 4 feet but enough for my needs. Car in gallery was LMB C6 Coupe. Wondering if anyone else owns one for maintenance, cleaning, and/or wrenching? Also wondering how stable??? Type? model? I can't find on SnapOn's site. :willy: Thanks, Reid |
:bigears
I saw that also Bone Daddy. My neighbor is a snap on Dealer. I mentioned it to him the other night. He said he could get one for me. If you can't find out any information on here. I will see what I can find out.
Here it is..
http://uucurl.com/x.php?p=1526 I have a few friends around the country who have them and love them. $4000 retail. |
How about this:
http://buy1.snapon.com/catalog/item....re&dir=catalog http://buy1.snapon.com/catalog/OBJECTS/35700/35644.JPG Description: Services a wide range of cars, light trucks, and vans. Ideal for tire shops, brake and wheel alignment shops, rustproofing operations, transmission shops, and more. Power pack with 12' hose and quick-disconnect are standard. Power pack also doubles as a tow cart to provide convenient flexibility for using the lift in multiple locations. Low drive over height allows lift to be easily positioned under a disabled vehicle. MID RISE PLUS SCISSOR LIFT for Tire, Brake and Body work, 6,500 lb. Capcaity, automatic mechanical safeties, twin cylinders, 52 3/4" maximum working height, single piece rollformed deck, 110 V/ 1PH/ 60 Hz. Features: - Space-saving scissors lift raises vehicle straight up with no fore or aft movement. - 48" lift height facilitates bodywork and tire, wheel, or brake service. - Low 4 7/8" drive over height allows lift to be easily positioned under a disabled vehicle. - One-piece solid deck accommodates cars, trucks, motorcycles, small engines and many large, odd-shaped parts. - Adjustable frame contact lifting arms rotate through 360° permit lifting at any factory approved frame lift point. - Pad style lifting with four standard lift blocks. Optional truck adaptors are available. - Newer safety features include five-position mechanical safety, foot pedal release of safety locks and twin cylinders with flow control monitoring system. - Oilite bushings at hinge points for maintenance free operation. - Power pack doubles as a tow cart to enhance portability. EELR338AP Mid-Rise Lift (Electric) Here is a great thread on another site: http://forums.pelicanparts.com/showt...hreadid=190582 |
I bought a bendPac for my garage.I got the low rise that takes it up about 30 inches for about 1200.00 ......4000 is kinda steep
Thanks!
Appreciate the timely feedback guys. Got to admit I wasn't expecting $4 grand worth of lift. I know...... SnapOn makes a good product.
At the moment I'm wondering if that electric "umph" isn't what is driving the cost up that high. On the other hand doesn't seem like that much steel-hardware in the frame design to drive costs that high. Wondering if it comes pheumatic only(???) Yo Vetteman22.....what is a bendpac? Please elaborate. :bigears |
Check this out:
http://cgi.ebay.com/ebaymotors/6000-...00184102QQrdZ1 |
Bend-Pak's Low Rise Lifts - 6,000 lb. capacity auto lifts
Model LR-60 Low Rise Lift This is the model that started it all! With it's 6000 lb. capacity combined with durable construction, the LR-60 is Bend-Pak's most popular model. It was specifically designed to increase effieciency and help make your job easier. Whether you choose the bolt-down model LR-60, or the portable model LR-60P, (see below), you can depend on raising profits and productivity. 6,000 pound lifting capacity Electric/hydraulic power system Hands-free safety system Rubber lifting blocks included Dropped cross bar for added clearance Heavy-duty steel channel frame Lifting capacity 6,000 lbs Lifting Height 26" Lifting Time 36 Seconds Lowered Height 4" Max Lifting Height W/ Blocks 29" Overall Length 82" Overall Width 70" Lift Pad Dimension 18" x 52" Motor - 110/220 VAC, 60hz, 1ph |
C6FirstVette is the one with the lift (and the LMB Corvette and an Elise).
I think that be me...buying the lift was the BEST purchase I made in a long time (other than getting my Vette :thumbs: ) Use it all the time
http://forums.corvetteforum.com/phot...h_lift-med.jpg http://i17.photobucket.com/albums/b7...U/C6onlift.jpg I show this pic because some of the lifts have a solid plate where the arms swing out...this will block access for areas directly under the car http://i17.photobucket.com/albums/b7...U/C6liftII.jpg Also if you have lowered your C6 (I have...just using the OEM adjusters so it is about 3/4" lower) or a low car to start with (Elise) you will need the boards to allow for clearance over the lift http://i17.photobucket.com/albums/b7.../garageIII.jpg Michael |
That's a nice looking lift and I'm sure it's good quality. But at 1K lbs., your not going to be moving that sucker around alot!!!
Great pics C6Firstvette!, would love meet up with you sometime next spring when I get back, don't think we live too far apart. Jeff |
Here's a link to Mohawk Lifts counterpart: http://www.mohawklifts.com/consumer/hr6.php
Mohawk is probably the best lift money can buy, bar none! |
Originally Posted by webdzynes
Check this out:
http://cgi.ebay.com/ebaymotors/6000-...00184102QQrdZ1 I presume this lift is Chinese goods with that price. Kinda scary that there is no brand mentioned. Gotta wonder about replacement parts. Either way thanks for the info webdzynes. Reid |
Mohawk is probably the best lift money can buy, bar none! BTW Michael, I think I have told you this before, but Mr. Blue and the Elise make me drool... VERY NICE! |
C6firstvette, Bud Gordon and all.......
Thanks C6FIRSTVETTE. This place is great. Hey I appreciate you chiming-in with the great info and pics. You have one sweet garage setup (and two awesome whips) there Bro. I'd be scared to drop or spill something on that clean perfect floor. :thumbs: Kudos!
Did you have to pony-up the $4 Bills for your SnapON or were you able to find a discount somewhere? (Rep, website, etc) Bud....very informative post esp the link you furnished. :seeya Thanks again Reid in Houston |
Actually I got a super deal... performance shop had the lift and used less that a year...maybe used 6 times and was in perfect condition...shop even change hydraulic fluid prior to my picking it up...deal was get it out of his shop by weekend (he was replacing with a HD four pole lift the following Monday) and it is mine for $1000... hmmm...let me think ;) Got my son and 5 of his buddies to move...weights about 700 lbs. I would look for a used one...maybe you can run into something like I did
Michael |
Bud and Jagcvette...thanks and absolutely lets get together after your return...maybe have a few other Vette drivers join us
Take care all M |
Does anyone have any experience with Directlift products? This one has a minimum height of 3 7/8" and seems reasonably priced.
http://www.directlift.com/auto_lifts/pro6mr.html http://www.directlift.com/auto_lifts...6mr_manual.pdf |
