Competition Mode?
Does anyone actually use this? Why should the Vette even have it???
Just want to add that im a new owner of a c6 this month and haven't really got the chance to enjoy it yet.....Weather... :thumbs: |
If you auto cross your car it lets the driver have a little more controll of the car but doesn't turn traction controll off completely. It will let you take the back end out before the computers start to correct for your errors. With everything turned off you can just to 360's and look like a "drifter".
MAY keep you out of trouble if you begin to lose control.
As Dave Hill said, the system works well to help you but it can't overcome the laws of physics. Use the AH/TC systems on the car like a warning- if they kick in it means you were trying to exceed your traction limits for those conditions. Maybe that's OK for the particular circumstances, but you should be thinking about what it means. I use the default "On" for wet roads, "Competition" for fun daily driving or road courses, and "Off" for autocrossing. |
I drive in this mode each time I start her. (Two quick depressions of the button.) I go back to default only when I get onto a freeway. When I first got the C6, I was pulling out of a fuel station and there was a little water at the approach to the street. When I pulled out I needed to give it a little gas to get out of the way of a car changing from the number 1 land to the lane I was entering. She fell flat on her face when the traction control shut her down. I didn't like it, so now I drive her all the time on competition mode.
Drag racing...
:thumbs: |
When I go to competion mode the dash tells me the traction control is back on.
Originally Posted by haljensen
Competition mode DOES turn Traction Control off, it modifies the Active Handling settings to allow more driver control.
Too. much gas 3000 pounds 430 crank hp
Comp mode is a good thing :thumbs: saved many from diaster :cheers: |
Competitive Driving Mode The driver can select this optional handling mode by pressing the ACTIVE HANDLING button on the console two times within a five second time period. A chime will sound and COMPETITIVE DRIVING MODE will be displayed in the DIC. Competitive Driving Mode allows the driver to have full control of the rear wheels while the Active Handling System helps steer the vehicle by selective brake application. The instrument cluster light will not be on. The Traction Control System will not be operating. Adjust your driving accordingly. When you press the ACTIVE HANDLING button again, or turn the ignition to ACC, the Active Handling and Traction Control Systems will be on. The TRACTION SYSTEM AND ACTIVE HANDLING-ON message will be displayed temporarily in the DIC and a chime will be heard. |
Originally Posted by famous1
... She fell flat on her face when the traction control shut her down. I didn't like it, so now I drive her all the time on competition mode.
Turn it all off if you autocross, you want to do the driving you will go faster with out it. :thumbs:
