'75 Catalytic Convertor
Here in New York, I have to have a catalytic convertor, since the 1975 originally came with one. BUT, it doesn't have to work since I am exempt from smog testing. (yes, that only makes sense to the politicians)
Any recommendations on the least restrictive cat out there at a reasonable price? Has anyone ever opened one up to gut it, and then welded back together? Any other ideas appreciated! Thanks! |
I'd get a cheapo and gut it by running a straight pipe thru it - No restriction.....
Any other ideas appreciated! Thanks! If this helps any, I gutted the "pre-cats" on my 2002: http://mikemercury.home.att.net/precats.htm this way - it still passes the visual inspection. |
Any recommendations on the least restrictive cat out there at a reasonable price? Has anyone ever opened one up to gut it, and then welded back together? Any other ideas appreciated! Thanks! I removed my stock cat and looked inside down the pipe. The element is very close to the opening of the inlet pipe, just take a long handled screw driver and have at it. You can get the insides out with no trouble. Then mount it back where you found it and when they look with the mirror it will pass... :cheers: |
Any recommendations on the least restrictive cat out there at a reasonable price? Has anyone ever opened one up to gut it, and then welded back together? Any other ideas appreciated! Thanks! Don |
Bash the center out, it will pass emissions no problem.
Thanks All!
some have a round plug knock it out clean and replace with a freeze plug :thumbs: a little grinding on the plug is needed
Just do it right so you don't have to worry about it.
http://www.ecklers.com/product.asp?d...XLJBBUTA8E97K6 BigBlockk Later..... |
