tcs and abs lights on c1221 c1232
Guys,
Need a little help diagnosing this recently my belt snaped and made a huge wipping noise and i noticed it wacked the abs connection right under the crank drive pully, this caused the abs and tcs lights to turn on and two codes to pop up c1221 and c1232. Any idea on what can be causing this. Thanks, Ralph |
Sounds like the BPMV module is not getting 12 volts. I am not home to look up your codes and I have a 2000 so codes maybe be different. That thing with six brake lines going to it is the heart and soul of abs and tcs. When I get home I will look up those codes for you.
Noe |
Tcs Abs
Greatly Appriciate It, This Thing With No Abs Or Traction Control In The Rain Can Get Pretty Intimidating.
Originally Posted by Rconce01
Guys,
Need a little help diagnosing this recently my belt snaped and made a huge wipping noise and i noticed it wacked the abs connection right under the crank drive pully, this caused the abs and tcs lights to turn on and two codes to pop up c1221 and c1232. Any idea on what can be causing this. Thanks, Ralph C1232 LF Wheel Speed Circuit Open or Shorted |
Guys,
Need a little help diagnosing this recently my belt snaped and made a huge wipping noise and i noticed it wacked the abs connection right under the crank drive pully, this caused the abs and tcs lights to turn on and two codes to pop up c1221 and c1232. Any idea on what can be causing this. Thanks, Ralph http://member.newsguy.com/~rmoburg/j...%20Bearing.jpg http://member.newsguy.com/~rmoburg/j...%20Bearing.jpg |
Check The Connection
How Do I Check The Connection Visually Or With A Voltmeter?
Since the belt tapped the connector a quick look might show you what is damaged. Do the easy things first. GOOD LUCK!!! :thumbs:
Visual Check
Will Do
Thanks |
visual inspection
Visual inspection indicates everything is good nothing broken or damaged and now there is a new code c1225 it seems the rf tire has joined the problem.
