klasse all in one
Has anyone used this product and if so what was it like,I need something for cleaning the acid rain etching off my vet and slight oxidation on my black boat,both surfaces loofk and feel great its only when you look at the right angle that the imperfection come alive.
You will see mostly great comments on this product, even from the "zaino only" crowd, as it truly is a great chemical and super light abrasive. When used with a Porter Cable Random Orbital is can really clean paint, remove overspray, and reduce minor marring. If the marks are harder and deeper into the finish, then you might wanna look to some polishes. These are very easy to use and provide nice results, you can even get the Klasse AIO there also. If you need a couponcode to save another 10% off, just PM me.
http://www.autogeek.net/pbmssr16.html |
I use Klasse AIO and Klasse Sealant on my other car (metal)
I love the stuff it gives off a different shine unless because it is a metal car and not like the Corvette. It transforms the finish into a very slippery surface. I did notice thought that the swirls and scratches I had before show up easier now for all to see but it still looks good and I use Zaino too on the C-6. I would say these are both great products. After claybaring and using the Klasse there was a big difference. :cheers:
AIO is the final product I use before any last step product, whether it's a sealant, wax or both. It works great on boats, glass, metal --- I find more uses for AIO all the time.
It's great stuff, leaves a clean, slick surface ready for wax. :)
AIO>than any other Acrylic Chemical Cleaner out there.
hands down. |
klasse all in one Has anyone used this product and if so what was it like,I need something for cleaning the acid rain etching off my vet and slight oxidation on my black boat,both surfaces loofk and feel great its only when you look at the right angle that the imperfection come alive. It will usually deal with light / medium oxidation JonM |
That is probably why after I used that product I noticed all of my swirls n scratches
Originally Posted by TOGWT
If the paint surface has been etched by acid rain you may need something more abrasive. Klasse AIO is primarily a chemical cleaner with a fine abrasive added that also provides athin acylic protection.
Klasse AIO is a really good product, has been proven over many years. Here is my latest detail job on my car using AIO:
Products used: Pinnacle Body Wash BlackFire Poly Clay Menzerna Final Polish II (new mix) Klasse AIO Menzerna High Gloss Acrylic Shield(applied w/ microfiber glove)4 coats applied 24 hrs apart http://forums.corvetteforum.com/phot..._29_050008.JPG http://forums.corvetteforum.com/phot..._29_050012.JPG http://forums.corvetteforum.com/phot..._29_050015.JPG http://forums.corvetteforum.com/phot..._29_050003.JPG |
Anybody ever try Griots products...specifically "Best Show Wax"?
Products used: Pinnacle Body Wash BlackFire Poly Clay Menzerna Final Polish II (new mix) Klasse AIO Menzerna High Gloss Acrylic Shield(applied w/ microfiber glove)4 coats applied 24 hrs apart |
Originally Posted by Killrwheels
Nice results D.K. ..... how did you like the Menzerna Acrylic Spritz. I have seen some light streaking over Zaino Z2Pro and wondered if it was a compatibility issue or direct sunlight (hard to escape it completely in Florida)
I've found it to be a wee bit temperamental. I do need to mist the trouble spots(streaks) w/ the product and rebuff out. Not a big deal really. (I do recomend you apply by using a nozzle similar to the extra fine mist of a Fabreeze nozzle). So, I don't think compatibility w/ Zaino is a problem. It is just the nature of the product. Don't apply too much. :flag: |
