86 Headlight Troubles
I searched the archives but didn't see this problem. When I turn my lights on the lights open fine. When I close them the left light goes nearly all the way down and stops and the motor runs on and on until I disconnect the wiring. The headlight at this point is open about 1 inch and is slightly loose????? :willy:
Any advise??? Thanks |
I'm having the same problem and am wondering how the motor comes out of the car.. :)
My 86 had similiar problems, the headlight would CLOSE but would not open.
I took the offender motor out - just a lot of bolts and screws to get it out - and opened it up. Inside there are three sets of contacts and depending on whether the contacts are open of closed the motor either opens or closed the door (up or down). I tried all sorts of "fixes" including buying three new relays, no good. I ended up sending it to CorvetteCentral for prepare since no one locally here in TX could do it. Chevy goes sell replacement parts for the 86 motor according to my local Chevy dealer. Their only suggestion was to upgrade BOTH headlights to the later (88) version. Mucho $$$$$$$$$$$ CC cost just over $100 and took a couple of weeks to get it back. No problem since. Jake |
you might try replacing the plastic gears inside the motor (2). these gears like to diisintegrate. my lights did the same thing. also i have left and right headlight buckets with the new motors for sale
Chevy goes sell replacement parts for the 86 motor according to my local Chevy dealer. Their only suggestion was to upgrade BOTH headlights to the later (88) version. Mucho $$$$$$$$$$$ Jake forget it. by the time i'm finished replacing all that crap i'll have half an 88 anyway. an 861/2 maybe. frog. |
Originally Posted by parafrog
that's the second or third time i've seen a recommendation to upgrade to the 88 setup to solve unreliable earlier c4 part problems. chevy must have figured the c4 out by 88. anybody want to trade an 88 for an 85?
frog. For example, (forgot the guy's name) one of the winningest road race guys says the 86 has the best chassis of them all. His 86 handled the best and he won more more races than with newer year chassises. After "upgrading" to a newer model, he went back to his 86 after his lap times fell off with the new iron and no matter what he did his "new" car couldn't run with his 86. So I'm wondering if it's cost-effective to move to an 88, etc., if it only take $100 to fix a malfunctioning headlight. You may well be swapping one problem for a different one. I wouldn't do it, but it's your call though. Jake |
I had a Corvette shop in Richmond, Va., replace the three bushings in the headlight motor casing of my 1990 Corvette. I saved money by removing the entire headlight assembly and taking it to the shop.
The headlights started out doing what yours are doing, but only got worse. Eventually, I could hear the motors running, but the headlights wouldn't pop up. The bushings are round pieces of plastic about the size of an man's index finger. After a while, the original bushings turn to sand. This was my 1990. I don't know if your 1986 has bushings. My headlights pop up with speed and power now. -- Eric |
85-86-87 Headlight Motor on E-Bay
There is a drivers side headlight motor on E-Bay. Four days to go on auction. Item number: 4524070578.
I am going to do the fix with the delrin bushings on my 89. Eckler's sent me the bushing kit, $4.95 per side, plus illustrated instructions. I also received plenty of help from the Forum members. Boatman Hobe Sound, FL |
86 Motor on E-Bay
[QUOTE=ddonzella]I searched the archives but didn't see this problem. When I turn my lights on the lights open fine. When I close them the left light goes nearly all the way down and stops and the motor runs on and on until I disconnect the wiring. The headlight at this point is open about 1 inch and is slightly loose????? :willy:
Any advise??? Check E-Bay, Headlight motor taken off of 86 on auction. Item number: 4524070578 |
Got the headlight assembly out of the car. Question, How do I seperate the motor from the headlight housing shaft??? :willy:
I have read so many problems w/ C4 and C5 motor, gear, bushing problems. I applaud GM for making the C6 headlight a "fixed" system!! :smash:
after all these years, they still couldn't design a reliable pop up headlight, so they gave up...Smart move on GM's part....wankers :cheers: |
Got it appart and found the small grey gear shot. Should be no problem fixing.. Thanks to all. :cheers:
