205 AFR Engine Dyno: A more complete picture
The info from these graphs can be found from the magazine, I just made the effort to input the information in excel to get it into graphical form instead of tabulated.
What you all have been waiting for, the power curves. The graph below shows the power curves of the Stock LS1, AFR with stock cam and AFR with "224" cam. The lower graphs are the difference in power between the LS1 vs AFR and LS1 vs AFR w "224" cam.
Same as above but with the torque graphs
This is the Intake flow including a graph of the difference in flow between the LS1 and 205 AFR Head.
This is the Exhaust flow including the difference between the LS1 and AFR head
Difference in power between the AFR and LS1 head, tabulated form
Power
RPM..........LS1..........AFR......AFR w 224.....LS1-AFR...LS1 -AFR 224
3.0............214..........217......... ..229...........3................15
3.5............257..........262......... ..274...........5................17
4.0............307..........323......... ..330...........16..............23
4.5............361..........375......... ..381...........14..............20
5.0............401..........427......... ..447...........26..............46
5.5............415..........451......... ..486...........36..............71
5.8............421..........455......... ..499...........34..............78
5.9............420..........458......... ..502...........38..............82
6.0............415..........457......... ..505...........42..............90
6.5............393..........451......... ..507...........58..............114
Torque
RPM...........LS1...........AFR....AFR w 224..LS1-AFR.....LS1 -AFR 224
3.0............375..........379......... ..401...........4.............26
3.5............385..........392......... ..411...........7.............26
4.0............403..........424......... ..433...........21...........30
4.5............421..........437......... ..441...........16...........20
4.8............426..........452......... ..462...........26...........36
5.0............421..........448......... ..469...........27...........48
5.5............396..........430......... ..464...........34...........68
6.0............363..........400......... ..442...........37...........79
6.5............317..........364......... ..410...........47...........93
The numbers should speak for themselves.
A little more tech info on the differences between the heads.
Vital Specs..................LS1......AFR
Intake Port Volume......201......205
Intake Valve Size..........2"......2.02"
Exhaust Valve Size......1.6"....1.55"
Chamber Volume........67cc.....66cc
I think these do the heads a little more justice
Edit: Thank you Jake for hosting!
[Modified by Pitch Black Z, 11:55 PM 5/13/2004]
Power
Torque
Re: 205 AFR Engine Dyno: A more complete picture (Bink)
These look nice, but I'd like to see it compared to LS6 heads cause thats what every one is using for better performance.
Re: 205 AFR Engine Dyno: A more complete picture (Darkness)
Excellent, understandable technical analysis. However, as has been said many times over, the bottom line on these heads is how much better they perform than the best, ported LS1/LS6 heads people are currently running. The base LS1 head is very old news, and not a particularly challenging baseline to use for flow, torque, and power comparisons. A more relevant test would be how they would fare against modified GM heads from a shop like Cartek that are available for around the same price.
Re: 205 AFR Engine Dyno: A more complete picture (marco383)
Look at the flow numbers vs port size. Most of the good flowing heads are in the 230CC intake port size range. Now, look at an out of the box AFR. Around the same flow, with a 205CC intake port. That means velocity.
Velocity means power...
Re: 205 AFR Engine Dyno: A more complete picture (Pitch Black Z)
I noticed in the article that the ls1 heads were quoted as having 1.6 exhaust valves where I though they come with 1.57--and the AFR heads come with 1.55--I talked to one of the members not long ago who had 2.1 intake and 1.57 exhaust valves on his stroker and it made good power is there something to capping off the exhaust flow or limiting it or is this because our heads don't have the potential we need and this is the best compromise for power--
Re: 205 AFR Engine Dyno: A more complete picture (J-Rod)
While I can't dispute the theory, I'd still like to see the graphs of the AFR 205 vs. ported LS6s on the same engine, same dyno, same sheet. This would provide a clear comparison of what are the current, likely alternative heads for a built, stock displacement motor.
Now for a counter-view.
IMO I think the AFR205's are a good upgrade from stock LS1 heads for those of us who want more under the hood but aren't looking for the 11sec club avatars. I like the gains from just the stock cam & AFR heads (ie something an average guy could swap on in a weekend). It also leaves me with the next level of a cam upgrade down the road if I choose without the driveability issues of a bigger cam.
If you want something to compare with the LS6 heads wait for the AFR 225's then fire away. There's your apples-apples.
Re: 205 AFR Engine Dyno: A more complete picture (Fast81)
Either do H/C or cam only.
Putting high flowing heads with punny little stock cam is such a waste
What am I missing? If I had a stock LS1 producing 421hp, 426 torque, even if measured at the flywheel, I think I'd leave it alone
This is one post from the other thread, and part of the reason I posted all the info, that needs some clarification.
If you look at the graph the power is peaking at 6.5k RPM where the difference in power between the stock and AFR 224 combo is 114bhp not 85bhp , not only that the power has not peaked at that point I'd say there was probably more power there and the difference would have been more if they had added a few more points past 6.5krpm.
I do agree that these heads do need to be tested against some ported LS6 casting as these are some of the best heads available at the moment but J-Rod pointed out another important fact. If the stock castings are ~200cc's porting them will only increase the runner volume. There have been a few ported castings that have been measured anywhere from 225-230cc's. With all else equal the AFR'S should perform better than any ported stock casting on a stock cube engine.
Another issue I would like to address is the drivetrain power loss. It has been my observation that its typically ~50-60hp for a manual transmission vehicle. This was backed up between what Tony Mamo's car dynoed from the engine to the chassis dyno. I would say that at 507bhp would equate to somewhere around 450-460rwhp, this is what Tony's car did on the rollers with this "similar"(not exact) cam.
There are a lot of "if", "ands" or "buts" but at this point this is the only solid dyno information, next to what Tony posted, and IMO there are going to be some more impressive power to be had with these heads over whats available in the market
I would love to see what these heads would do on a G5X car
[Modified by Pitch Black Z, 12:03 PM 5/14/2004]
So let me get this straight,
They got:
37bhp with AFR heads vs. stock unported LS1 heads and
85bhp with AFR heads/224/114lsa cam vs. stock unported LS1 heads/stock cam
All this on a car that had LS6 intake, ported TB, headers, hi-flows and exhaust.
This not bad, but nothing super-duper if you ask me.
I'd estimate a bolt on car like this to put down ~340-345rwHP.
Add 85bHP (~72rwHP)- we're looking ~420rwHP
They got:
Re: 205 AFR Engine Dyno: A more complete picture (EuG)
Why? Someone recently reported a 42 hp gain from heads only on a stock system. I'm definately considering a set of Patriot 5.3 litre heads with a set of comp magnum true roller 1.85 rockers. That's 547 lift and 10.9 compression The patriot heads flow 296 CFM@550 which is only 6 CFM lower than the 600ish lift cams. I think a respectable 40ish rearwheel horsepower gain could be seen from a 1200 dollar set of heads + 300 dollar rocker arm package. This would be an easy set up to install, it upgrades for valve train, and leaves the car running like stock.
Re: 205 AFR Engine Dyno: A more complete picture (Demented)
Do you have the graph of that dyno?
Again pay attention to the runner volume of the heads. How much of that flow is from increase runner volume and how much of it is from improved velocity? It isn't meant as a bash towards any vendors or any manufacterers product, lord knows there is already to much drama on forums, its just some food for thought.
If you can't run 11's with just the heads, its not AFR's fault. I agree with EUG, if you do the heads, you might as well throw a cam in there too. There are plenty of cams that don't sacrifice anything.
Bruce
Bruce
I would be very interested to see some real hp #'s and 1/4 mile track ET/MPH's with a heads only setup. I think there are a fair number of people who are willing to swap the heads but not the cam. Swapping the cam can cause emissions issues as well the installation costs are more than doubled.
Mark
CF Co-Founder
Moved to C5 Performance Results.
What about the 225 heads and what kick azz cam could I use with them when they come out?
