Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
243 heads - port & polish
Old 02-10-2018, 07:44 AM
TheCartel
TheCartel's Avatar
Guys Katech has the best deal going.... 499...
Luweegy (01-26-2019)
Old 02-10-2018, 07:28 PM
Calibear2003
Calibear2003's Avatar
not really the best deal. You need to send them your bare heads as the $499 price is for porting only. Their port program is old via 2003-2004 period. This included nothing else. This information was from Jason at Katech. So, if you needed a valve job and the deck taken down a bit, you would still need to find another shop. I read this a few months back on ls1tech.
Old 02-11-2018, 05:10 PM
silver408z
silver408z's Avatar
Some of the other deals included new valve springs as well.
Old 02-12-2018, 10:09 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Valve job and decking are available
http://store.katechengines.com/valve-job-p595.aspx
http://store.katechengines.com/deck-...eads-p588.aspx
__________________
Contact:
(e) zach@katechengines.com
The following 2 users liked this post by Katech_Zach:
CorvetteBrent (09-07-2018), Luweegy (01-26-2019)
Old 02-14-2018, 02:44 PM
MvP_LS2
MvP_LS2's Avatar
I say hold out and just stalk Craigslist and the Facebook marketplace for heads. I check them daily and it really paid off last week. I got a set of CNCd 243s for $500, cash. The guy had them ported then sold the truck and didn't ever install. Have all the paperwork from the machine shop, including a 3 year warranty.
Deal of the century?
Old 02-16-2018, 08:18 PM
TheCartel
TheCartel's Avatar
Originally Posted by Katech_Jason
I've got a set of 243's there now, arrived Thursday looks like.
Old 02-17-2018, 02:23 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Final pouring size is just as important as gains, bigger isnt always better
Wouldnt shop porting by price its not all the same and agree that polishing is a colossal waste of time, mostly for appearances sake, kind of like a signature.
Old 02-19-2018, 01:24 PM
sstonebreaker
sstonebreaker's Avatar
Originally Posted by Roddy13
I'm going with the Frankenstien heads myself.
Let us know the results. I live just outside Weatherford, TX and had I known they were local I would have given them a shot. I went by there a few months ago because AI sent me the wrong head bolt kit (GM specifies the short head bolt kit for '04 and above, but my engine needed the old style head bolt kit), and they only charged me the difference in price to swap them. Seem like good guys.
Old 03-31-2018, 04:12 PM
Cookee
Cookee's Avatar
I have 2005 LS2 A4 with AI 226 heads 63cc, 224/230 600 112 cam,fast and kooks 1 3/4 headers. RWHP 465 RWTQ 443.
I was at 420 rwhp 401 rwtq prior to heads installed.
Old 04-06-2018, 03:56 PM
sstonebreaker
I had an England Green Mayhem 2 cam and bone stock 241 heads on my '04 manual. It made 408 rwhp on the dyno. I ran it for three years without freshening the valve springs and paid big time - two of my lifters started bouncing off the cam lobes and eventually shattered and lunched the engine.
During the rebuild, I had AI do my 241 heads. In addition to the port work, they welded up and reshaped the combustion chambers to 58 cc, which I believe will bump my compression ratio to 11.5. AI estimates that along with the 234/242/112 cam, I should see around 460 rwhp.
Since I also burned the clutch, I decided to replace it with the C5 LS7 kit that Scoggin Dickey offers. It's a little heavy and may bring down my peak hp a little, but the OEM reliability is a good tradeoff for a few peak hp.
I should be getting it dynoed here in the next couple of weeks.
Well, apparently AI knows their stuff:
Old 07-25-2018, 07:25 PM
gnharley
gnharley's Avatar
I would have to agree with you on that ! What is the lift on that cam & what lifters & springs did you end up with ? And is this a 5.7 LS1 ?
Old 08-16-2018, 10:50 PM
jdwtx85
jdwtx85's Avatar
Originally Posted by FrankensteinE.D.
westmma385,
I can't beat $750. For $1150 you'll have new .660" spring kit with Ti retainers. CNC port, CNC valve job, Laser logo, hand blend, surface, final wash and assembly.
-Russ
Rus are those numbers with a exhaust pipe?
Tsp prc 225 cast heads. In a ls2 have done over 500 many times to the tire with a btr4/ms4/polluter style cam and fast
Old 08-19-2018, 11:03 AM
  #33
cv67
cv67's Avatar
St. Jude Donor '05
Sounds equivalent to a good Gen 1 220-230cc head ought to run well. The noticeable thing is the LSx heads do it with a 2.00 in valve, not a 2.02 2.05 2.08 etc.
To get 290cfm through a Gen 1 intake port wiht a 2.00 valve you usually have to butcher it to death.
Old 08-28-2018, 11:22 PM
  #34
_zebra
_zebra's Avatar
also take into account when comparing those 2 flow bench charts that Frankenstein's are on an LS1 bore while TSP's are on LS2 bores, which will net a little higher numbers (if i remember right)
Quick Reply: 243 heads - port & polish
