Highest HP/TQ bolt on C5Z? 442/395
#101
Actually not many people here seem to be interested in what he did...most people are trying to discredit his results...
If they truly were interested I'm sure he'd share but lots in this thread are too busy saying he has a happy dyno or that the different mods he had won't make any difference over normal in of the mill ones
#102
But people shouldn't be chastized for asking questions about a unique combination that has yielded results that really haven't been seen before (at least by most people here.)
#103
I tuned the car on my dyno. Both the first time, second time, and third time. Scotty did have someone "tune" his car on the street thinking it would make it better (it, actually, made it worse) and he added a MAF with a "MAF curve" that was provided to him (which was horrible and left the car very lean at WOT). So I had to do a lot of clean-up this past visit.
i don't mind answering any questions anyone has about Scotty's build or chain of events with his build.
Im really busy, so I may be a bit slow to respond. I'll chime in with quotes where I can if anyone is interested.
#104
I found his results difficult to believe. I have a scientific mindset, so if the evidence makes sense I have really no choice but to believe where the evidence leads. I've asked questions and I've also responded and acquiesced when things made sense, such as on the injector issue.
#105
#106
He's a good guy that did his homework and he also has taken what I've said to him at our past sessions and has applied them, successfully! Breather, Catch Can, false knock, stuff like that.
And I don't mind helping others with their builds when I can.
I believe he used the Texas Speed MAF curve.
Its a waste of time! I used one of my own I've built and have used successfully from the past. I also use linear smoothing over edited cells for a better blend. It's nice and smooth and consistent!
someone did ask about injector data. His injectors are maxed out. I did warn him. Nothing a set of whites can't fix! Then I can verify and make some minor adjustments in the injector data if he'd like while on the dyno.
also, my dyno is certified by dyno-dynamics on a regular basis. I also don't fudge the "smoothing" of the graph nor the correction multiplier.
Actually, because of this, I was able to see the top end having issues and I found that he had put the timing at 24 degrees (which is scary) on our 91oct Fuel here! The knock sensors had been turned off as well!
But overall, the car feels strong and I'm really interested in seeing what it does at the track!
#107
I would any of my customers that are down to learn and understand more about this hobby!
#109
Originally Posted by DPnSider
This showed up in my email, but not in the thread. Thought I'd post it up. If "BoostedLS" checks back in, something weird happened.
Nice work op
#110
I got the car re aligned today. Seems to hook up better now under acceleration. Maybe the previous owner took it to a road course lol.
#111
Originally Posted by BoostedLS
Thanks! I wasn't sure what happened. I'm new to the forum but have been following Scotty's threads. I tried posting twice and didn't see anything show up so I gave up.
Nice work op
Nice work op
#112
Gave it my all last night. Finally starting to figure out this clutch after about 20 passes. I've never been the best driver but it's nice having a clutch that takes a beating. I hot lapped it about 6 times around 9:30 pm and got a new PB.
#114
Interesting.
I'm a tuner and dyno operator.
Dyno Dynamics to be exact.
So first question, were your numbers right off the Dyno? Or are they from the "Brand X" comparison that Dyno Dynamics provides?
That would be closer to a DJ.
Our customers always frown when we give them the true DD readings. Until they go to the track.
I haven't dyno'd either of the cars listed in my sig.
I only have tuned both at the track.
So what power do you think my LS1 is making?
#117
Interesting.
What's the set up on your LS1?
#118
Stock bottom end.
Older AFR 205 heads
EPS 226/230 .600 116 cam
Fast 102 intake
LS2 TB
85mm Z06 MAF
Headers
Vararam
Everything but the cam was bought used.
Auto trans, which costs mph due to converter slippage.
Not sure why my .sig doesn't show up automatically any more.
Ron
Older AFR 205 heads
Fast 102 intake
LS2 TB
85mm Z06 MAF
Headers
Vararam
Ron
#119
Former Vendor
What was the DA the day you ran? When I correct mine to a DA of sea level I get 11.95 @ 121.5 mph which seems to be on par with yours. If your car was running that in bad air then you have something there.
#120
