Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
finally put my auto swap on dyno
Old 04-14-2014, 09:54 PM
BuddhaZ06
BuddhaZ06's Avatar
Default finally put my auto swap on dyno
2001 z06.
A4. 4000 stall. 3.42 gears
Fti streetsweeper cam
Ported ls2 intake & t.b.
Ud pulley. 1-3/4 LT's.
Made 395/355 unlocked
415/375 locked up.
Old 04-15-2014, 07:59 AM
pit-man
pit-man's Avatar
Originally Posted by BuddhaZ06
2001 z06.
415/375 locked up.
That should really move and be a blast to drive
Old 04-15-2014, 04:39 PM
Blow Torch
Blow Torch's Avatar
Yep; That's gonna run well
Did you dyno before the swap?
Old 04-15-2014, 06:02 PM
RonSSNova
RonSSNova's Avatar
Looking forward to the ET and MPH
Ron
Old 04-15-2014, 07:46 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Solid numbers for stock heads! Especially thru an auto..
Easily an 11.50 car..
Old 04-16-2014, 12:04 AM
BuddhaZ06
BuddhaZ06's Avatar
Thanks guys. Only had it on the dyno when it was bone stock. Best e.t was 11.39@124 with different cam and bigger heads and no headers. I then put the auto in and ran 11.42@119 with a 3400 stall with a very easy launch. I then went to stock heads and put headers on. Then dyno and now haven't went to the tech m track yet. Hopefully sooner than later!
Old 04-16-2014, 12:05 AM
BuddhaZ06
BuddhaZ06's Avatar
I'm gonna weigh it tomorrow. Should be right around 3000
Old 04-16-2014, 07:56 AM
ajrothm
ajrothm's Avatar
Damn you must have some serious weight reduction...
I'm surprised you lost 5 mph from the stick to the auto... The converter must have been very inefficient..
Old 04-16-2014, 08:47 AM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
reminds me of Casper.
My experience with a very similar set up is that you'll love it.
Congrats.
Old 04-16-2014, 01:37 PM
BuddhaZ06
BuddhaZ06's Avatar
Well it was a very easy pass. My first with the swap. And with the m6 it usually trapped 122-123. The 124 was great weather. Wasn't great weather with auto in.
Old 04-16-2014, 01:56 PM
BuddhaZ06
BuddhaZ06's Avatar
Stopped at the scale and it was all over the place. Really windy today. It was around 3,050 the most IG but not real accurate. A/c removed. No front sway bar. 18" wheels.
Old 04-18-2014, 08:45 AM
BuddhaZ06
BuddhaZ06's Avatar
Now that I think about it. I still had the 4.10's in the car and think I ran out of gear before the 1/4
Old 09-15-2014, 11:05 PM
BuddhaZ06
BuddhaZ06's Avatar
Finally went to the track. 11.8@118 with a 1.7 60'. Probably won't get to it this year but I'm gonna get some stickier tires and skinnies and go try again. The 555r just don't hook for me at the track. I think I'm losing a little time on my 2-3 shift when it flares some.
To finally put my auto swap on dyno
Quick Reply: finally put my auto swap on dyno
