Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
View Poll Results: Whp gain with:TPIS 90MM intake/90mm tb fully ported??
Less than 15whp
60.00%
Between 15whp to 20whp
6.67%
Between 20 to 25whp
33.33%
Between 25 to 30whp
0
0%
More than 30whp
0
0%
Voters: 15. You may not vote on this poll
Whp gain with:TPIS 90MM intake/90mm TB fully ported??
Old 11-02-2013, 11:52 AM
always faster
always faster's Avatar
Default Whp gain with:TPIS 90MM intake/90mm TB fully ported??
Lets make a small poll for this one
I got a 383 and im putting down 490whp/461wtq with a stock untouched ls6 intake and stock untouched 78mm tb.So i was looking to improve my intake.
Note:
1-I did not use a Fast 90 or 92 because i had one on my first setup and the lower sheel cracked twice because of the cheap plastic.
2-I did not use a Fast 102 because after some test fit,it was rubbing/hitting my cowl.There is no way i would cut my car for a intake and will not use shorter engine mount.
So the TPIS 90mm ls6 was the way to go.A solid ls6 gm base with a 90mm opening.But they are kinda rare in the used market.Ive found one a couple weeks ago for a faire price and bought it.I will use a 90mm ls2 tb.Both will be professionaly ported and the transition between the tb and the intake opening will be seem-less.
So simple question:
After some tune adjustment ,how much whp should i gain ???
Hoping for at least 20whp
Eric
Old 11-02-2013, 03:03 PM
dankhts
dankhts's Avatar
I only picked up 11 rwhp on my heads/cam C5, from about 3,500rpm and up, lost a bit below that though, ported Fast 92/90 and a well respected tuner.....I was hoping for more but I got about what he told me to expect....
Old 11-02-2013, 11:18 PM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Id say 10hp but more importantly 25lbft with additional tuning.
Old 11-05-2013, 09:00 AM
always faster
Well kinda depressing...10whp...
I guess that the 25 torque is something good.
Old 11-07-2013, 09:05 AM
always faster
Would it hurt me a lot by skipping the porting job on the intake ???I mean if spending 125$ + both shipping from canada for a port job is useless i would not do it.
I could just slap the ported ls2 tb on it and thats it.Maybe tring to make a seem-less transition myself but left the intake in stock form.
Old 11-08-2013, 11:22 AM
PRE-Z06
PRE-Z06's Avatar
Received 2,053 Likes on 1,305 Posts
Curious what heads you're running?
FWIW here's my results from an LS6 to a 92...
http://forums.corvetteforum.com/perf...-maf-10hp.html
Old 11-09-2013, 01:39 PM
always faster
Im running:
PRC LS6(243) stage 2.5 : http://www.texas-speed.com/p-4-prc-s...ted-heads.aspx
383 ci built by TSP(all callies) 11:1 CR
Cam: 240/244 ,.615"/.619" @ 113 lsa (EXR lobe)
All the support mod(ARH 1 7/8 ,Vararam,morel lifter,manton custom pushrods, etc etc)
Built tr6060/c6z diff complete setup,twin disc clutch,adj master,poly tube coupler etc etc)
No cheap parts but did wanted to say simple.
Old 11-09-2013, 03:40 PM
PRE-Z06
PRE-Z06's Avatar
Originally Posted by always faster
Im running:
Sounds like a solid build and the intake is definitely the bottle neck, so you should see some better gains. Have you ever logged your kpa?
Old 11-11-2013, 04:57 AM
always faster
Better gains, well finally something positive to hear
I dont know the KPA reading since im do not tune the car.
If i can have someting in the 505whp/480wtq minimum range, i ll be happy
Old 11-13-2013, 11:28 AM
mchicia1
mchicia1's Avatar
Did you use the button head bolts on the valley when you had your first fast 90? It's a common problem for people not to install them and they end up cracking the intake.
Anyway, on a 383, you will pick up 30 from 4k and up with a fast/ls2 tb, no doubt about that. I even gained 25 on my little 346.
To Whp gain with:TPIS 90MM intake/90mm TB fully ported??
Quick Reply: Whp gain with:TPIS 90MM intake/90mm TB fully ported??
