Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
what is required to run 15" wheels?
Old 05-12-2013, 08:23 PM
Tar Heel
Tar Heel's Avatar
Default what is required to run 15" wheels?
I've done a search and can't come up with a comprehensive list. What exactly is required to run 15" x 10" and 15" x 4" wheels? This is for a 2004 coupe. I'd like to run perhaps Weld Pro Stars with 28" drag radials and a skinny front.
Thanks.
Scott
Old 05-12-2013, 08:40 PM
4DRUSH
4DRUSH's Avatar
For the rear, you need different spindles.
LG makes some that allows you to run your stock rear brakes.
The rear A arm will require a small notch on the bottom
Depending on the shape of the rim barrel, you won't have to grind the rear caliber or use a spacer.
The Pro Stars have a square barrel shape, should be ok
For the front, you can run Strange light weight brakes or
I believe you can run the rear brakes on the front, but might require a spacer (not sure)
Old 05-13-2013, 04:12 PM
Tar Heel
Tar Heel's Avatar
Thank you sir. I will continue to investigate this. My CCW Classics, with the black centers, aren't growing on me yet. They're much lighter than OEM wheels but I would like all "shiny" wheels as a friend of mine says.
To what is required to run 15" wheels?
Quick Reply: what is required to run 15" wheels?
