Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
First Supercharged run
Old 02-17-2013, 01:00 AM
Speedaemonc4
Speedaemonc4's Avatar
Default First Supercharged run
Just finished upgrading to a procharged ls2 setup, havent dynoed but went to the track Friday night and jumped straight onto the track running an 11.8 at 134 into a cold front head wind. On the second run got a 11.6 at 132, thinkin I need some better tires, running Nitto NT-01s right now, had a 1.9 60ft on the first run, 2.0 on the second. My old turbo setup was fun but the instant power from the procharger sure make me smile bigger,
Old 02-17-2013, 08:09 PM
skydiven4fun
skydiven4fun's Avatar
St. Jude Donor '13-'14-'15
My car is in the middle of having a A&A kit installed right now, I'm looking forward to that first time behind the wheel. Sound like yours is running really sweet.
Old 02-17-2013, 09:02 PM
evo2ls1
evo2ls1's Avatar
great mph, I just finished my FRC with bolt ons and A&A kit, made 3 passes car ran 11.6, 11.3, and 11.2 between 129-130, you have a fast ride sir trapping 134!
Old 02-18-2013, 07:00 AM
pit-man
pit-man's Avatar
You will be in the 10's with some good rubber
Old 02-19-2013, 10:35 PM
danieloneil01
danieloneil01's Avatar
Great mph but jesus that time blows even with that sixty. Post your slip. If you can't hit the 10's with DRs then you need to sell the car. 1.9 isn't bad with that much power on street tires so you should be able to run deep into the 10's with DRs.
Old 02-20-2013, 12:14 AM
RonSSNova
RonSSNova's Avatar
6 speed?
Old 03-12-2013, 04:11 PM
MONSTAA_C5
MONSTAA_C5's Avatar
You're going to love the new-found power. I haven't put enough miles on to get used to it yet. Drives normal until you build 3k rpm and hammer it!
Old 04-12-2013, 10:02 AM
LSX_NUT
LSX_NUT's Avatar
Way to be a douche man. Maybe he was taking it easy on the shifting because his drivetrain isn't built yet or that he was spinning all the way down the track. Cut the guy some slack.
To First Supercharged run
Quick Reply: First Supercharged run
