Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
C5 LS3 TSP 231/236 cam only rough tune dyno results
Old 08-24-2012, 04:42 PM
C5Natie
C5Natie's Avatar
Default C5 LS3 TSP 231/236 cam only rough tune dyno results
Well, the car still needs quite a bit of tuning but I got a baseline on my current rough tune. Car dynoed at 460rwhp/455ftlbs on a Superflow eddy current dyno. Needs less timing up top and a lil less fuel. 1 7/8 headers and intake porting are in my future plans. Still as is, its making 20-30 more ftlbs of torque then most LS3's Ive seen with this cam. Hopefully some more tuning can net me another 10-15hp.
Stock L92 shortblock
Stock LS3 tb, intake, heads and rockers
TSP 231/236 114lsa cam
PRC .675 valvesprings
TSP 1 3/4 headers
(Forward vid to 1:08)
http://www.youtube.com/watch?v=2xClOO8xxVM
Old 08-25-2012, 11:02 AM
Sales@Texas-Speed
Premium Supporting Vendor
Sales@Texas-Speed's Avatar
I said it before Ill say it again. Congrats on the numbers, and I definitely look forward to seeing the finished results. Should make for a super fun street car!
Old 08-28-2012, 09:43 AM
C5Natie
C5Natie's Avatar
Looking at the dyno sheet, would you say 6500 would be a good shift point?
Old 08-28-2012, 10:18 AM
pit-man
pit-man's Avatar
Typically 200 rpm past peak, so 62-63 would work. By 6500 you are dropping off bad.
Old 08-28-2012, 11:47 AM
C5Natie
C5Natie's Avatar
Cool, my tuner also agreed with 6300. After peak power at 6000 it only dropped 9hp at 6400 so the drop is not that bad but shifting at 6300 should keep me in that sweet spot.
Old 08-28-2012, 12:30 PM
pit-man
pit-man's Avatar
I use a small shift light and set it about 300 rpm before my shift so I don't go past. I figure by the time your eye sees the light, and your brain signals your hand\foot, it will take that much time to actually bang the gear.
Old 08-28-2012, 11:44 PM
RonSSNova
RonSSNova's Avatar
It's an A4, don't need a shift light. Set the software (easier said than done) where you want it to shift and go in 3.
Old 08-29-2012, 08:23 PM
C5Natie
C5Natie's Avatar
Adjusted the shift points to 6300 and man I feel a difference. No drop off in power and the shift comes in hard. You can really tell the car stays in its sweet spot. Got wot timing at 28*, was at 30* but playing it safe. Its been hot out here but its running good. Since these LS3's seem to run a bit hotter Im now looking at a bigger radiator. Bigger headers will have to wait for tax return season.
Old 01-15-2013, 07:53 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
nice results, lift was under .615?
Old 01-19-2013, 12:07 PM
rlncoalctd
rlncoalctd's Avatar
Maybe going to forget about a 416 short block and just do a stock ls3 with my trick flow 235s, nice cam, and my fast 102... Your numbers look great...torque!
Old 01-19-2013, 04:50 PM
speedmon
speedmon's Avatar
How did you deal with the 24/58 wheel/computer issue?
New computer or conversion box?
CA car....think that will smog?
To C5 LS3 TSP 231/236 cam only rough tune dyno results
Quick Reply: C5 LS3 TSP 231/236 cam only rough tune dyno results
