Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Performance Results
Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette? Sponsored by
BFGoodrich
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-14-2011, 09:39 PM   #1
LSOHOLIC
CF Senior Member
LSOHOLIC's Avatar
manual trans.??
After skimming through some of the fast list build threads I have a question. Who still has there T56 in their cars ??
So...whos running 10.50's or faster with a real T56 ?? No pro shifted, dog ringed, faceplated, slippers or TR6060 conversions.
Whos really going fast with factory 6 speed ?? M6 or M12 ?? And of course.....if it needed beefed up thats fine....but I would also like to know what you have done to make it live.
Thanks.....just fyi, I'm ECS brace, 3 rib 4.10 ECS stage 2 diff and a BC2 clutch. And roughly 500na and a little spray.
LSOHOLIC is offline   Reply With Quote
Old 12-14-2011, 10:08 PM   #2
123sugey
CF Senior Member
Support Corvetteforum!
123sugey's Avatar
I own PRAYS old Z06 and will not go auto even though at the hp level I have it would be quicker. I'm hoping (praying) for a solid 9 sec et.
I've had the fast auto cars before but rowing gears and getting there first is the best
123sugey is offline   Reply With Quote
Old 12-15-2011, 03:41 AM   #3
baezi z06
CF Senior Member
baezi z06's Avatar
Bæring Jón Skarphéðinsson
Send a message via MSN to baezi z06
I still have my T56 in my car
best up to date is 10.1@143.7 60ft 1.63 lack of traction on 26" tires
it´s MN6 only thing done to it is new syncroms, billet keys and bronze fork pads.
last summer i broke my pinion carrier in the diff and the mainshaft, so i upgraded to Gforce 9310 mainshaft. (this didn´t happen at track tough just few days later after a 10.3@140 run )
SPEC 3+ clutch steel Flwh + Tick master
Diff is stock housing whith C6 Z guts ECS brace and stock gears 3.42
but my driveline is a ticking timebomb...
bigger tires and more juice to come....
I´M GOING AUTO
i think T56 is good up to 700 maby 800rwhp whith hardened mainshaft but then the diff is already a trouble, you could get away whith t56 and a C6 diff conversion on that powerlevel for some time maby but after that a TR6060 and built C6 Z diff is the only way to go in a stick car
good luck
Baezi
baezi z06 is offline   Reply With Quote
Old 12-16-2011, 09:32 AM   #4
LSOHOLIC
CF Senior Member
LSOHOLIC's Avatar
Thanks guys.....it seems there are very few true T56's left. Damn....thats not a good sign for me . O'well...we will see what parts puke out.....
Clemonsdave...what trans are you running your 9.97 with ??
Thanks.......
Old 12-16-2011, 10:04 AM   #5
Tsab
CF Senior Member
Tsab's Avatar
Been using the T-56 with hardened shafts etc. No real issues with it, best pass has been 10.28 at 138. I run a dual disc McLeod clutch.
__________________
MOD's Cartek Racing 2X Heads & Blower Cam, Ported Intake & Throttle body, P1SC-1 Supercharger@8.5 PSI, ARH Headers & X pipe, 653 HP 517 Line lock, Neverlift 5pt Roll Bar, MN 6 Trans by RPM / AMR , CCW Drag Package, McLeod RXT clutch inst by ECS, Snow Prfm Meth Injctn by AMR. New Best ET (2008) with S/C 10.28 best et 137.8 best mph 60 ft 1.43 View My Video
RIP Leo Barnaby & Mike Conway
Tsab is offline   Reply With Quote
Old 12-16-2011, 10:11 AM   #6
baezi z06
CF Senior Member
baezi z06's Avatar
Quote:
Yes and good clutch setup is offcourse very imortant when people are pushing it specially on higher horsepower levels....
Mcleod dual is a good clutch also i´ve seen people who run RPS are very glad whith it...
Baezi
Old 12-16-2011, 05:04 PM   #7
clemsondave
CF Senior Member
clemsondave's Avatar
Send a message via MSN to clemsondave Send a message via Yahoo to clemsondave
Thanks.......
Stock untouched trans.
Stock untouched 3.42 rear (well, hardened output shafts).
McLeod RXT Twin
Zero broken parts, but I didn't abuse it
It would be much faster with gears, but I like keeping it stock.
clemsondave is offline   Reply With Quote
Old 12-16-2011, 09:42 PM   #8
Rick@RKT56
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12
Rick@RKT56's Avatar
pages/RKT56/244463478927497
From my experience, it's not the T56 that's the weak link but it's the diff. The main output shaft breaks when the diff goes and not the other way around. If you build the T56 with 30 splined shaft and run the C6 Z06 diff, I think that should be good to 10.0 to 9.80. If you want to go faster, TR6060 is a must.
__________________
Rick@RKT56 is offline   Reply With Quote
Old 12-16-2011, 10:00 PM   #9
nickolbag
CF Senior Member
nickolbag's Avatar
I just went right to the TR6060 now that I'm making a little power. Didn't wanna hope the old stuff held up.
nickolbag is offline   Reply With Quote
Old 12-16-2011, 11:51 PM   #10
LSOHOLIC
CF Senior Member
LSOHOLIC's Avatar
Quote:
Hey Rick or Tsab.....is it a pretty in-depth process to R&R the main output shaft ?? I would assume so.....and I just had that **** out doing the BC2 clutch, ECS brace and ECS stg 2 4.10 diff ..... The reason I dicided to not touch the trans was my plan for a T.M. faceplate it in the spring..with a slipper of course. But depending on which way the wind blows I may change my mind again . Im still not sure if the slipper/faceplate is right for me. Like I said...depends on which way the wind is blowing. And I want to see first hand how far I can push the T56...I have some personal goals in mind that I'm looking to do with the car and maybe after that I can do the "full C6Z cradle, diff and trans deal".
Im so ready to get this beotch to the track its not funny. You guys would fn shoot me if I told you the circus that I've caused myself...haha....example...same heads have been on and off twice....and never fired...haha...now they are on there way back to B.T.'s for some chamber softening and "extra" massaging. But she should produce...and that will be well worth the 6 months shes been down.
Phuck...I could ramble all night about the resoning behind the indecisions...haha....
Thanks for the feedback guys.....can I get in on some....."best section in the forum" statements. Haha....after I heckled that Canadian...haha....
Old 12-17-2011, 05:16 AM   #11
baezi z06
CF Senior Member
baezi z06's Avatar
What is you setup btw. ? how much are you gona spray ?
When are you gona hit the track?
are you still running stock C5´s outputshaft´s ?
what tires will you be running ?
Baezi
Old 12-17-2011, 08:31 AM   #12
LSOHOLIC
CF Senior Member
LSOHOLIC's Avatar
Baezi
Well...'04Z
1)with the drag pack she weights 2840lbs or 3010lb with me
2)346 SBE with worked 243's, cam and manifold~500ish-rwhp (n/a)
3)N. Outlet direct port with stand alone fuel system (not sure on how much....just chasing an ET...so what ever it takes....and I run with some of the best n2o guys in the country ....to help with the tune)
4)stock t56, RPS/BC2, ECS 4.10 with harded shafts and brace
the two things that will be on the car before she down the track is the LG drag spindle and QA1's on all corners.
And about the tires.....on the n2o it will be a M/T slick (28x10.5/15). Hoping the sidewall will help....a lot.
And dragging it to Texas for the initial n/a tune (this week or the week after newyears) and will hit the concrete palace !! And drive it 4 hours home...because it is a real pump gas ZO6 street car.
Thanks.....
Old 12-17-2011, 07:12 PM   #13
baezi z06
CF Senior Member
baezi z06's Avatar
Well...'04Z
Thanks.....
It´s light weigt.....
that 4.10 gears on 28inch and N2o will be awesome,
post some results when you go
good luck
Baezi
Old 12-18-2011, 11:38 AM   #14
GARY2004Z06
CF Senior Member
GARY2004Z06's Avatar
good luck
Baezi
Good luck with it and keep us posted.
GARY2004Z06 is offline   Reply With Quote
Old 12-18-2011, 01:38 PM   #15
LSOHOLIC
CF Senior Member
LSOHOLIC's Avatar
Thanks guys....I'm hoping the 15" slick will help the rear....and trans hold together. When I weighted the two different set ups (15x10 prostars w/28" M/T slicks vs C4 GS knockoffs with Hoosier 315 DR's) it was 17lbs lighter per side with the 15"ers. Some I hoping that the rotating weight and the sidewall helpout a bunch.
Thanks......anybody have back to back data on the 17" vs 15" ?? Arun ??..basically interested in 60' and mph differences between the two.
Old 12-18-2011, 02:14 PM   #16
tirecraft
CF Senior Member
tirecraft's Avatar
Well...'04Z
Thanks.....
We ran a similar set up in Kyles street car . Head /Cam /200 shot /t56/410- 10.00 all day long. We used a Tex 0z700 and a 16 inch slick 1.41 60 ft
The 15 inch tire should help .w We lost a few ring and pinions and some main shafts it got expensive, swapped to the Rpm TR6060 kit and never looked back. Added a 402 CI and went 9.25 @155 banging gears no faceplate or slipper clutch ,stock weight plus the cage ...
tirecraft is offline   Reply With Quote
Old 12-18-2011, 04:00 PM   #17
GARY2004Z06
CF Senior Member
Old 12-18-2011, 05:57 PM   #18
tirecraft
CF Senior Member
tirecraft's Avatar
Quote:
Originally Posted by GARY2004Z06 View Post
That's when racing was fun .... Now .... lol
Old 12-18-2011, 07:41 PM   #19
LSOHOLIC
CF Senior Member
LSOHOLIC's Avatar
You guys better start cleaning your pm boxes out now....cuz I'm going to be filling them up with launch videos so you guys can give me pointers .
On a side note...since the car is weeks away from firing.....thought I'd indulge in a little bench race (theory). With the M12 1st gear being so steep (2.97) I've been running the numbers on a possible second gear launch (2.07).....remeber I'm 4.10 rear. Picture this...stage the car in second...which would let me leave on more spray and would eliminate one shift...aka..one less time the n2o turns off. So a three shift 1/4 mile pass. And with less "torque multiplacation" on the line and more n20 I should 60' quicker...in theory. So the progressive box would look something like this...50% off the line and 7 tenths 100% of a 150 jet. Thats kind of how I have my 66 Nova setup...but it a glide and a whole different ball of wax.
But I do understand that is a lot of "load" on the driveline....and I will be losing the mechanical multiplication factor. But from my experiance....less gear more "jug" off the line...and vise versa.
Thanks...and Gary...what kind of numbers does a bolt-on C6Z put to the tire ?? And with that torque curve...I imagine shift recovery is second to none. And who thinks I'm crazy to think I'll make 440ftlbs from this 346 at the tire ??
Reload this Page manual trans.??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
