Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2009, 10:43 AM   #1
HinsonSuperCars
Supporting Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-267-6387
Default 603 rwhp 583 rwtq - LS3 427 NA!!
LS3 427ci built by Hinson Motorsports
Naturally Aspirated, Pump Gas, Hydraulic Roller
- LS3 427ci Shortblock
- Trickflow 235cc CNC Ported Cylinder Heads
- GM MLS LS7 Head Gaskets
- Yella Terra Ultralite Roller Rocker Arms 1.7 Ratio
- Hinson Motorsports HM1 Camshaft
- Ported FAST 92mm Intake
- FAST 92mm Throttle Body
- SLP 25% UD Pulley
- Stock GM Water Pump
- Hinson Motorsports 4" Cold Air Intake
- Hinson Motorsports 1 7/8" Long Tube Headers
- Hinson Motorsports 3" Y-Pipe
- Hinson Motorsports 3.5" Exhaust System
- SPEC Stage 3+ Clutch
- SPEC Steel Flywheel
Dyno Run
Right Click Save As
http://www.hinsonsupercars.com/Pics/...LS3427Dyno.mov
603 rwhp 583 rwtq
HinsonSuperCars is offline   Reply With Quote
Old 11-11-2009, 10:44 AM   #2
HinsonSuperCars
Supporting Vendor
Hinson Motorsports LS3 427ci Shortblock
- GM LS3 Block
- K1 4.125" Crankshaft
- K1 6.125" Rods
- ARP Rod Bolts
- Clevite Rod Bearings
- Diamond Flat Top Pistons
- Total Seal Rings
- ARP Main Studs
- Clevite Main Bearings
Hinson Motorsports LS3 427ci Longblock
- Patriot LS2 Double Roller Timing Set
- ARP LS3 Head Bolts
- GM LS7 Lifters
- Comp Magnum Pushrods
Old 11-11-2009, 10:44 AM   #3
HinsonSuperCars
Supporting Vendor
Engine Assembly
Old 11-11-2009, 11:24 AM   #4
Capthuff
CF Senior Member
St. Jude Donor '09-'10-'11
Capthuff's Avatar
Very cool...
What's the compression ratio?
And please educate me.
Why does it seem to be more popular to use the LS3 to build a 427 as opposed to the LS7?
Capthuff is offline   Reply With Quote
Old 11-11-2009, 11:37 AM   #5
rammer
Junior Member
How aggressive is the cam? How is the idle/street manners??
rammer is offline   Reply With Quote
Old 11-11-2009, 07:54 PM   #6
HinsonSuperCars
Supporting Vendor
Quote:
Originally Posted by Capthuff View Post
Very cool...
Compression is 11.3. The LS3 Block is $1,142 cheaper than the LS7 Block. This is the ultimate engine package for big cubes at a low price.
Quote:
Our Camshaft is 24x duration with big lift. It has a nice lope to it and idles smoothly.
Seth
Old 11-11-2009, 08:58 PM   #7
paint it black vette
CF Senior Member
paint it black vette's Avatar
from what i understand about the k-1 crank they have straight journal oiling which will ensure constant flow rather than oil flow stall at intersections. is this that much better than the cross drilled cranks and could you elaborate on which cranks are cross drilled. how much rwhp can the k-1 take
paint it black vette is online now   Reply With Quote
Old 11-12-2009, 11:04 AM   #8
Chicago1
CF Senior Member
Chicago1's Avatar
Pm me how much is something like this to build and install and what is the time frame? Minus the clutch and flywheel.
Chicago1 is offline   Reply With Quote
Old 11-12-2009, 11:43 AM   #9
BillY2KFRC
CF Senior Member
BillY2KFRC's Avatar
Send a message via AIM to BillY2KFRC
Very impressive setup, I'm thinking the LS3 may be the better route for me to go 427cid when I'm ready. Great numbers, must be a monster on the street.
Also, with the LS3 block, do you avoid some of the oiling issues I've read about with the LS7 block using wet sump?
BillY2KFRC is offline   Reply With Quote
Old 11-12-2009, 07:45 PM   #10
HinsonSuperCars
Supporting Vendor
Quote:
At this power level and type of use, the standard oil journal works fine. We don't have a list of cranks that are cross drilled.
Quote:
PM sent.
We did not have any issues converting the LS7 to wet sump. There should be no reason for a problem. The blocks are the same when converted. Let us know if we can help and feel free to contact us if you have any more questions.
Seth
Old 11-16-2009, 11:33 PM   #11
Z06wanted
CF Senior Member
Z06wanted's Avatar
Very nice.
Z06wanted is offline   Reply With Quote
Old 11-19-2009, 09:38 PM   #12
Corvette Don
CF Senior Member
Corvette Don's Avatar
WOW, im drooling. Got any 408/418 shortblocks? Pm me a price if you do.
Corvette Don is offline   Reply With Quote
Old 11-20-2009, 01:24 AM   #13
CF Senior Member
are the k-1 cranks and rods made in america?
Old 11-20-2009, 08:13 AM   #14
holley505
CF Senior Member
holley505's Avatar
Send a message via Yahoo to holley505
Is it true you should NOT use power adders with a stroke over 4.1? being the piston is close to the bottom edge of the block?
Also can you give specs on the camshaft and power range? You sell that by itself? I have a LS3 418 stroker now. I lOVE IT!
__________________
Old time 12.03@114.6 1.72 60ft old setup
1/8th mile?!? 6.91@100 1.65 60ft
High 10s with 3rd gear!
One owner 77 vette ** LS3 stroker with a CARB! It RUNS! TS&P 418 wicked cubes
00 SLP SS M6 Camaro sold
00 FRC cam and headers 375rwhp with ls1 intake
holley505 is offline   Reply With Quote
Old 11-23-2009, 07:56 PM   #15
HinsonSuperCars
Supporting Vendor
Thanks guys!
Quote:
4.000" Crankshaft = 418ci. The price is the same. PM sent.
All the major Crankshafts/Rods in this price range are made offshore.
For mild forced induction applications, you'll be fine with the larger stroke. For extreme forced induction applications, we recommend the 4.000" stroke. Our Camshaft is 24x duration with big lift. The power range is to 6500 rpm. Yes, we can sell this Camshaft by itself for $374.99.
Seth
Old 11-23-2009, 08:30 PM   #16
holley505
CF Senior Member
holley505's Avatar
Quote:
Seth
What is the LSA? Can you give that? Thanks
I have a 418 with a Carb.
Old 11-24-2009, 03:35 PM   #17
tirecraft
CF Senior Member
tirecraft's Avatar
Great power !! Mustang or Dynojet ?
tirecraft is offline   Reply With Quote
Old 11-25-2009, 10:38 PM   #18
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
- GM LS3 Block
- K1 6.125" Rods
- ARP Rod Bolts
- Total Seal Rings
- ARP Main Studs
- GM LS7 Lifters
KILLER POWER naturally aspirated at a great price!
__________________
2006 Black C6 Z06, black powder coated rims, CAI; B&B Bullet Exhaust, and of course 427 Badges ; Mopar Jimmy is back with a daily driver 2008 Dodge Challenger, 450hp Hemi SRT8, runs 12.7s with bolt ons, & a mean, Ralleye Green, 1969 Plymouth Road Runner machine, 600hp 505 ci, black steel wheels & black fiberglass 6-pack lift off hood. Thanks and Praise to GOD!
Mopar Jimmy is online now   Reply With Quote
Old 11-30-2009, 07:49 PM   #19
HinsonSuperCars
Supporting Vendor
112 LSA.
Quote:
Thanks. It's a Dynocom Dyno.
Old 12-31-2009, 05:33 PM   #20
HinsonSuperCars
Supporting Vendor
New lower pricing on the Longblock Assembly!
Reload this Page 603 rwhp 583 rwtq - LS3 427 NA!!
Tags
418, 427, black, block, blown, compression, crankshafts, flow, head, heads, ls3, ls7, na, ny, problems, stroker, trick, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
