Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2009, 03:45 PM   #1
JDaniel
Senior Badass!
St. Jude Donor '08-'09
Support Corvetteforum!
JDaniel's Avatar
Default Worked out the tune!!!
So I have been having problems with the car so I decided to work on it a little this week. Here were the problems that caused major issues:
Very rich AFR (even on the 10.54 pass)
The electrical system was having issues
I kept getting a MAF code
Reduced Engine performance over and over
A/C and heat only blows ouyt of the defog
The AFRs have been stuck at 12.0 while driving, 11.5 and richer on the motor tune WOT and then when I sprayed it the AFRs would drop to 10.3 to 9.7 om the nitrous tune WOT.
So me and a friend looked at the car and found the negative post to the batt was a little loose and tightened it up. We took it for a ride to advanced and most of the bucking it was doing under a load in 5th and 6th cleared up but we tested the batt anyway. Batt showed up as bad. Im assuming thats where the MAF code was coming from because it hasnt come back and the car drives great now.
We replaced the batt and come to find out the old batt was leaking down into the tray. Now I know why the A/C and heat only blows out of the defog now.
I took the fuel and nitrous lines off the nozzle to see what jets were in it for the 100 shot. NX says a 100 shot is supposed to be 52N and 28F. I had 52N and 35F in it. So thats why it was running rich as hell. So instead of changing the fuel jet we installed a 62 for the nitrous side and left the 35 for fuel, making it a 150 shot. We hooked the HP Tuners pro kit to it and did a little tuning. The car feels 100X stronger on spray not. We didnt adjust any fuel, timing or anything. Its a perfect 11.8 afr till 6000 rpms and then it drops to the very high 10's which is fine by me. We are getting no knock, and no timing retard while the timing hangs between 18 and 21 degrees. I can thank the NGK BR7EFs for that.
Anyhoo... thats my update for now. Im hoping for a 10.2-10.3 if not better next time out at the track. My laptop went down and waiting for it to get fixed so i will check in on my phone till then. take care everyone!
JDaniel is offline   Reply With Quote
Old 11-07-2009, 07:45 PM   #2
Capthuff
CF Senior Member
St. Jude Donor '09
2004 Chevrolet Corvette
Capthuff's Avatar
Glad to hear the news...
Looking forward to some new times from you now...
Capthuff is offline   Reply With Quote
Old 11-08-2009, 08:19 AM   #3
Zosickness
CF Senior Member
Zosickness's Avatar
That's great news getting stuff sorted out! Too bad everyone isn't so lucky.
Zosickness is offline   Reply With Quote
Old 11-08-2009, 08:46 AM   #4
simpleman68
CF Senior Member
simpleman68's Avatar
Congrats on working out the bugs. With sophisticated technology, there are so many variable to consider. Particularly, when one can effect another. Feels like a wild goose chase I'm sure.
Scott
__________________
2004 M6 MSG
AMR forged 384 N/A
10.83 @ 130.40 (1.70 60') DR's
11.22 @ 128 (2.0 60') Street tires :nod:
http://www.youtube.com/watch?v=BCDpFvbMLCM
simpleman68 is offline   Reply With Quote
Old 11-08-2009, 07:20 PM   #5
JDaniel
Senior Badass!
JDaniel's Avatar
Ok... so here is the issues now and I dont even know where to start. LOL I took it out and all the problems are fixed exept for the A/C issue. I went out and jabbed the gas and hit second pretty hard. The check engine light come on as well as the "reduced egine perormance" and here are the codes I pulled.
P1120
P1516
Im assuming the Throttle Actuator control is bad? What can you guys tell me about thi code?
Old 11-08-2009, 08:04 PM   #6
camotruK
CF Senior Member
why are you running 12.0 when driving around...the 02 sensors/fuel trims should curve it to 14.63 under normal driving conditions not in PE
camotruK is offline   Reply With Quote
Old 11-08-2009, 08:05 PM   #7
camotruK
CF Senior Member
p1120 TPS sensor...dont they rebuild those?
Old 11-08-2009, 08:06 PM   #8
camotruK
CF Senior Member
the p1615...TAC not sure what thats all about...perhaps they go hand in hand?
Old 11-09-2009, 07:13 AM   #9
JDaniel
Senior Badass!
JDaniel's Avatar
Quote:
I think it had something to do with the bad ground. when im cruising now it stays close to 14.0.
Where is the TPS sensor located on these cars?
Reload this Page Worked out the tune!!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My first SHOT from the Bottle! Major Spray Performance Results 14 08-16-2005 04:10 AM
A MUST read in conjunction with the TUNING related topic!!!!!!!! ski_dwn_it C4 Tech/Performance 75 03-26-2005 11:32 AM
Finished the roll cage norvalwilhelm C3 Tech/Performance 45 11-17-2004 08:19 PM
[SMC] New Event at the Rush (June 26) Loco Vette Southeast 121 07-05-2004 06:28 PM
Figured out the FAST 90mm intake and TPIS 90mm TB gremlins rwj383 C5 Tech 36 04-25-2004 01:20 PM
How are my #'s after Dyno Tune? C5JONNY C5 Scan & Tune 12 02-07-2004 10:09 AM
Car problems out the exhaust.... (figuratively) kscorvettekid C4 Tech/Performance 10 09-15-2002 08:42 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
