Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2009, 02:30 PM   #1
FSTFRC
CF Senior Member
FSTFRC's Avatar
Default The Good and the bad!
I went to the track yesterday out in Crandall Texas (Dallas Raceway) great weather yesterday to run the car. Track was not crowed at all, there were only had a few break downs, and the car hooked up great. Overall with 30 to 45 minute cool downs I got 6 passes!
Modifications: Cam, Ported 243 heads, Ported LS6 intake, ASP underdrive pulley, SLP Blackwing,Dynotech Super Max Headers with cats, Corsa Touring Cat Back Exhaust
The Good:
First pass on street tires:
When I picked up the time slip I knew it was going to be a good day, on that pass I had to get out of second gear because of axel hop.
60 – 2.09
330 – 5.602
1/8 – 8.413
Mph – 88.33
1000 – 10.776
¼ - 12.728
Mph 113.03
Second pass I barrowed a set of BF Goodrich Drag Radials from a friend:
Left at 3000 rpm and slipped the clutch. I was pumped fastest time the car ever ran!
60 – 1.973
330 – 5.397
1/8 – 8.110
Mph – 90.50
1000 – 10.424
¼ - 12.372
Mph – 112.08
Third pass:
Launched at 3000 rpm,this turned out to be the best mile per hour for the day.
60 – 1.944
330 – 5.38
1/8 – 8.103
Mph – 90.95
1000 – 10.405
¼ - 12.33
Mph – 115.76
Fourth pass:
Driver and car was getting consistently faster! Launched at 3500 rpm.
60 – 1.914
330 – 5.318
1/8 – 8.011
Mph – 91.57
1000 – 10.301
¼ - 12.229
Mph – 113.36
Fifth pass:
I hit the rev limiter in third gear so that killed my mph and probably my 11 second pass! Left at 3500 rpm on this pass.
60 – 1.810
330 – 5.166
1/8 – 7.86
Mph – 90.87
1000 – 10.170
¼ - 12.105
Mph – 112.90
Sixth pass:
At this point I thought, I’ll lower the air pressure from 22 psi in the drag radials to 20 and leave at 4000 rpm. All this did was slow down the E.T. and cause the tires to spin. Plus I heard a noise when I shifted into second gear on the drivers side rear.
60 – 1.908
330 – 5.361
1/8 – 8.099
Mph – 89.37
1000 – 10.437
¼ - 12.397
Mph – 111.32
Now for the Bad:
I thought I would let a friend make a pass and it broke the output shaft on the drivers side on the starting line. Not his fault I probably broke out put shaft the on the sixth pass.
Now I have to think about whether to just fix the car with a regular GM half shaft or go ahead and spring for a RPM differential with 3:90's
Oh well it was a fun time at the track yesterday except for breaking the car! I know there is more in the car just need more practice.
FSTFRC
FSTFRC is offline   Reply With Quote
Old 11-02-2009, 02:33 PM   #2
camotruK
CF Senior Member
you dont have to redo the whole diff...just put a hardened shaft in there and keep at it...the C6Z is a cheap upgrade or you can do a hardened one from RPM or DTE for like 300 bux
what kind of power are you making and with what clutch?
camotruK is offline   Reply With Quote
Old 11-02-2009, 02:49 PM   #3
FSTFRC
CF Senior Member
FSTFRC's Avatar
It's a LS7 Clutch. Car made 420 rwhp and 400 rwtq. Car has the stock gearing in it (M6 with 3:42's). I was having to shift into fourth at around the 1000 foot mark. thanks...
Old 11-02-2009, 02:51 PM   #4
Capthuff
CF Senior Member
St. Jude Donor '09-'10-'11
Capthuff's Avatar
Very nice!
So close to 11s...
Yeh, what Camo said... Just put in a C6Z shaft for about $100 or so. Unless you want taller gears... I really like my 4.10s
Capthuff is offline   Reply With Quote
Old 11-02-2009, 08:37 PM   #5
FSTFRC
CF Senior Member
FSTFRC's Avatar
Quote:
Originally Posted by Capthuff View Post
Very nice!
So close to 11s...
Thanks.. I was so close to that 11s.. slip!
Old 11-02-2009, 10:14 PM   #6
slowtealz28
CF Senior Member
slowtealz28's Avatar
Send a message via AIM to slowtealz28
Nice job, you will hit the 11's soon. Just make sure you didn't snap the output shaft of the trans.
slowtealz28 is offline   Reply With Quote
Old 11-02-2009, 10:31 PM   #7
camotruK
CF Senior Member
keep working on your shifting with 420rwhp and a 6sp you should be 120+
Old 11-03-2009, 12:17 AM   #8
CNB
CF Senior Member
Support Corvetteforum!
CNB's Avatar
Good job Joe! I heard the timing was messed up out there. Your mph was probably faster.
P.S. Don't forget about the 3.90's I have.
CNB is offline   Reply With Quote
Old 11-03-2009, 12:23 AM   #9
JGOAT
CF Senior Member
JGOAT's Avatar
yea joe it was fun sorry about your car,but hey you were running good
JGOAT is offline   Reply With Quote
Old 11-03-2009, 08:14 AM   #10
JDaniel
Senior Badass!
St. Jude Donor '08-'09
JDaniel's Avatar
Nice runs, man! You will see that 11 sec pass before you know it. then you will be shooting for something bigger.
I had both outputs upgraded and went with the 300M shafts. I launch at 4000-5000 on slicks ad spray and I havent broke eiher yet (knock on wood!!!). LOL
JDaniel is offline   Reply With Quote
Old 11-03-2009, 10:45 AM   #11
FSTFRC
CF Senior Member
FSTFRC's Avatar
Thanks Everyone!
Well I decided since the car was down to go ahead and set the rear end up with an RPM Stage 2 differential with a 3:90 gear set. Car should be back together next week. I choose the 3:90’s because I wanted to have the car set up close to a C5 Z06 gear ratio.
FSTFRC
Old 11-03-2009, 11:27 PM   #12
JON CONA
CF Senior Member
JON CONA's Avatar
Jeff.....there is a member in the c5 for sale section that has a new lpe left shaft up for grabs......good luck with your repair.....jon
JON CONA is offline   Reply With Quote
Old 11-05-2009, 10:39 PM   #13
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Joe comparing 2 slips from ennis and crandall where I couldn't go into 4th gear at the 1/8 and trapped 98mph at both places, I coasted to the 1/4, but there was a 4mph difference in trap speeds, so it looks like you would've have trapped 120mph on the best run...heard you decided to go with 3.73s instead, car should be done next week and we're talking about possibly going to an event at ennis on the 14th since the track doesn't hook as hard...sorry again man, Chris
PRE-Z06 is offline   Reply With Quote
Old 11-06-2009, 10:28 AM   #14
FSTFRC
CF Senior Member
FSTFRC's Avatar
Quote:
Hey Chris no problem man! Thanks for your help and advice. I went with 3:90's, man it's going to be hard to put the required miles on the diff. before the 14th.
Joe
Reload this Page The Good and the bad!
Tags
bad, corvette, good, history
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Good News and The Bad......... fastdriver1 C6 Corvette General Discussion 23 04-16-2005 09:16 AM
GM does care Check 6 C6 Corvette General Discussion 33 03-05-2005 03:39 AM
Question for all you C6 Owners 02stlpewter C6 Corvette General Discussion 56 12-31-2004 10:32 AM
Got my Vette back..........the good and the bad 96VegasVette C4 General Discussion 16 10-20-2001 02:50 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
