Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-01-2009, 10:57 PM   #1
tommie
CF Senior Member
tommie's Avatar
txgumballmachine
Default C5 drivetrain....
questions.......
At what point should I need to do "upgrades" to my rear differential... (DTE)?
I have 388 RWHP 383 RWTQ current best et is 12.55 at ~112mph...still on street tires....
Will be doing a clutch sometime in the near future, and drag radials....
saw winters post on breaking his car, and some people saying it is the shaft in the differential...
at what point (hp, or et?) should I need to upgrade? and what should I upgrade to?
hardened shaft? which one? which brand?
trans/diff brace?
This car will not be an all out race car, but most of its abuse is taken out at the 1/4 mile dragstrip....
tommie is offline   Reply With Quote
Old 11-01-2009, 11:04 PM   #2
Stevo92z28
CF Senior Member
Stevo92z28's Avatar
When they break is when you need to upgrade
If and when you do the clutch, i would do the brace and possibly the output shaft then. As long as your not getting wheel hop with the street tires you should be fine. I'm on drag radials with stock clutch and it's working well. It's not that hard of a launch cause i slip the clutch. I'm still in the 1.7 60's for now hoping to work down to the low 1.6s. Not worrying too much myself, but if it breaks it breaks... Luckily if i break my car now i have the whole winter to fix it and i won't be down for next season.
Stevo92z28 is offline   Reply With Quote
Old 11-01-2009, 11:18 PM   #3
tommie
CF Senior Member
tommie's Avatar
txgumballmachine
^ yea I have the if it breaks it breaks attitude too, but was just wondering at what level these things break...
I have thought about doing the brace and output shaft when I do the clutch... just have to see how the cash flow is at the time....
link for shaft
link for brace
is DTE the cheapest place to get them from? Or can you find DTE parts from another vendor cheaper?
Old 11-01-2009, 11:49 PM   #4
Capthuff
CF Senior Member
St. Jude Donor '09-'10-'11
Capthuff's Avatar
IMHO, ECS has a better designed brace.
I have it on my car.
http://eastcoastsupercharging.com/
Capthuff is offline   Reply With Quote
Old 11-02-2009, 12:00 AM   #5
tommie
CF Senior Member
tommie's Avatar
txgumballmachine
http://eastcoastsupercharging.com/DTE_Strut_Brace.html
this one?
Old 11-02-2009, 01:01 PM   #6
Capthuff
CF Senior Member
Capthuff's Avatar
yep
Old 11-02-2009, 03:28 PM   #7
evo2ls1
CF Senior Member
it breaks at stock power level or 887 hp lol, mine broke with the 340 rwhp, but i as running mt et streets i would just wait til my last stock one breaks unless you already have the drivetrain out
evo2ls1 is offline   Reply With Quote
Old 11-02-2009, 10:10 PM   #8
slowtealz28
CF Senior Member
slowtealz28's Avatar
Send a message via AIM to slowtealz28
I broke my output shaft, ring and pinion, and diff casing with 331rwhp and street tires. Wheel hop will rip these things apart, and anyone who saw the carnage knows it was absolutely DESTROYED. If I had to do it all over my first mods would have been a clutch, rear, and tires.
If you are going to race the car, get at least a good rear with both shafts hardened, along with the brace. Why not spend the extra couple hundred bucks and risk having the other shaft snap? I have an RPM trans and stage II rear and I love it. I just wish I woulda changed out the clutch of all destruction (spec twin) while everything was out.
slowtealz28 is offline   Reply With Quote
Old 11-02-2009, 11:20 PM   #9
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Quote:
And why is that?
vettenuts is online now   Reply With Quote
Old 11-02-2009, 11:42 PM   #10
Capthuff
CF Senior Member
Capthuff's Avatar
Perhaps dte has changed their design, but, theyused to use washers as spacers where it bolts to the diff. ECS designed theirs so it wouldn't need spacers. It just fits like it was designed specifically for our cars.
Old 11-03-2009, 02:14 PM   #11
BERGN8R
CF Senior Member
BERGN8R's Avatar
Quote:
I was going to say just before or just after it breaks. I've done both. I ran 2 years on the stock stuff than added an aftermarket diff before I added any HP and broke it on the third trip to the track. Last Sunday, about 4 years later, broke the output shaft on a stock Z06 diff that replaced the aftermarket one. I did not put in hardened shafts, but will this time.
Rebuilt the trans last winter because I lost 5th & 6th, I would assume that was not race related. Wheel hop does break things but they also break without it as in my case.
BERGN8R is offline   Reply With Quote
Old 11-03-2009, 02:45 PM   #12
SmoothFRC
CF Senior Member
SmoothFRC's Avatar
Do the brace... you can always re-use it - and you dont want to break the tranny case along with the rear....
SmoothFRC is offline   Reply With Quote
Old 11-03-2009, 03:58 PM   #13
BERGN8R
CF Senior Member
BERGN8R's Avatar
Quote:
Has anyone broken a tranny case?
Old 11-03-2009, 04:17 PM   #14
SmoothFRC
CF Senior Member
SmoothFRC's Avatar
Quote:
What do you think the brace is for?
here is the description of the product from the ECS site:
The problem of differential case fracture, transmission case breakage and driveline deflection during hard acceleration on the street, road course or drag strip is a common, inherent problem with the C5 Corvette that often shears the differential away from the attachment point at the transmission. A trans / rear brace is the best way to limit the potential for case fracture on your big horsepower corvette.
Old 11-03-2009, 04:31 PM   #15
BERGN8R
CF Senior Member
BERGN8R's Avatar
I know what it is for. I used to have one and took it off. That wasn't the question. I have seen many threads here about broken diffs but I do not recall a single one about a broke tranny case. I suppose you buy stuff from infommercial on TV as well.
Old 11-03-2009, 04:40 PM   #16
SmoothFRC
CF Senior Member
SmoothFRC's Avatar
Apologize if i came off sarcastic ...... just stating what is in "writing". Over the years i have read many posts and saw the pics to back them up of people breaking both the tranny and rear cases. This was fairly common before and DTE Brace was introduced (in the FI/Nitrous section)
I have one on my car for pure insurance - i dont drag my car that much, but putting down more then enough power to break things. I am not saying my rear will not break, but if it prevents the tranny case from breaking - it is well worth it.
Old 11-03-2009, 04:50 PM   #17
BERGN8R
CF Senior Member
BERGN8R's Avatar
[quote=SmoothFRC;1572032345]Apologize if i came off sarcastic ...... QUOTE]
I've heard agruments for and against, but honestly, never seen a post here regarding broken trans case. I have my own reasons for taking it off but would not try to convince anyone not to use it if they want to.
Reload this Page C5 drivetrain....
Tags
2002, c3, c5, corvette, deflection, driveline, drivetrain, loss, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
this makes sense to me just wondering what your c5 made sotck on the dyno pionexxxx C5 General 51 03-04-2005 05:12 PM
How much HP can the C5 drivetrain handle? NitrousMan C5 General 15 02-09-2005 12:07 PM
345/30/18 BFG DR's on a blown C5? AWSM_06 C5 Forced Induction/Nitrous 38 04-27-2004 04:26 PM
Putting a C3 body on a c5 chassis battsup C3 Tech/Performance 24 02-23-2004 11:11 PM
C5 drivetrain loss BiZ C5 Tech 10 06-03-2002 09:08 PM
C5 Drivetrain Upgrades - Carbon Fiber! Godspeed C5 Tech 19 01-23-2002 08:38 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
