Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2009, 03:53 AM   #1
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Default ported fast 90 results...
I'm reluctant to post this as I'm a little disappointed in the numbers, but I've never been one to get caught up on dyno numbers. I do however like to know my money spent was worth while and honestly thought I'd see more gain than 1hp! It actually lost 1ft/lb, but the curves overlayed look identical, never varying more than a couple either way and the peaks are at the same rpm? SOTP it felt similar to when the heads were ported and it gained 30rwhp then. I'm hoping the dyno was out of calibration or something, since the shop I've been using from the beginning just recently moved. Hopefully the track numbers will tell a different story this weekend...I know my cam isn't big enough to really take advantage of the intake, but it sure feels faster. Maybe my butt-meter is out of calibration as I'd been up for 24hrs when we finished it up. Afterwards, I did run my buddies 408 auto c5 that's turned 10.6@126 and "only" lost to him by 2 cars from 40-120, which he said was about the as same when he ran against a 470rwhp lg cammed ls3 c6...figured I'd share, any thoughts?
PRE-Z06 is offline   Reply With Quote
Old 10-29-2009, 06:49 AM   #2
GARY2004Z06
CF Senior Member
Support Corvetteforum!
GARY2004Z06's Avatar
The Dyno is great for tuning. The track is the real test. Has the car been retuned for the FAST?
GARY2004Z06 is offline   Reply With Quote
Old 10-29-2009, 07:09 AM   #3
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Yes we street tuned it after the install, granted the pulls were from different days too. I'm hoping it gains a couple mph and is enough to push it into the tens, will know tomorrow night possibly. It'd be nice to trap as fast as your bolton c5z Gary
Old 10-29-2009, 08:29 AM   #4
Fartpipe
CF Senior Member
Send a message via AIM to Fartpipe
Track the true test of your modding results And we all like to see dyno results though too so I hear you on that one. If the car feels better then hopefully it is. If you lost to your buddy by approx 2 car lengths is about 2-3mph difference. From my findings. It doesnt come down to ET for roll races as it does HP/TQ resulting in MPH.
Fartpipe is offline   Reply With Quote
Old 10-29-2009, 09:06 AM   #5
GARY2004Z06
CF Senior Member
Quote:
Focus on your goal and you will realize it.
Old 10-29-2009, 10:14 AM   #6
CTD
CF Senior Member
CTD's Avatar
Not using the same dyno for the before & after makes it difficult to compare results. If you take some time to compare several dyno runs & the results to both the dyno's you may be able to draw some conclusions that are useful.
The dyno results aside you can safely believe your SOTP meter assuming your Fast 90 was done properly.
You don't need a cam to see big results, head over to the C6 Tech section & search, you will find it is not uncommon to have similar gains with a ported Fast 90 as Long-tube headers. Many stock before & after dyno runs are posted there.
I have noticed the manifold really starts to flow @ 4000 rpm & requires tuning to compensate, the tuning required is adding fuel. Commonsense is that when adding fuel you are making more power.
You can always reveiw your tuning & see what the changes were.
CTD is offline   Reply With Quote
Old 10-29-2009, 11:45 AM   #7
11sec_C5Z51
CF Senior Member
11sec_C5Z51's Avatar
What kind of numbers are you making??
11sec_C5Z51 is offline   Reply With Quote
Old 10-29-2009, 12:22 PM   #8
chaase
CF Senior Member
chaase's Avatar
Take it to the track and find out. If you didn't run it on the same dyno then the differences could be attributed to that. It would have helped if you did a before run on the same dyno to put things into perspective.
chaase is offline   Reply With Quote
Old 10-29-2009, 02:47 PM   #9
LS1LT1
CF Senior Member
LS1LT1's Avatar
Send a message via AIM to LS1LT1
I'm surprised no one has asked this yet (or maybe everyone already knows) as it is somewhat important but what intake manifold was on there before the FAST, an LS1 intake or LS6? Ported or untouched?
Stock 75-78mm throttle body or ported/polished?
I'm assuming that it was an LS6 as the gains from going to a FAST over an LS1 intake, even if measured on separate dynos, would have to be quite substantial.
LS1LT1 is online now   Reply With Quote
Old 10-30-2009, 01:39 AM   #10
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Quote:
Thanks Gary, I'm definitely "in the zone", all I can hear is the engine revving and if I close my eyes I see the tach needle swinging lol. The weather is supposed to be in the 40's tomorrow night(should be -DA) and I'm gonna see what she'll do. Ya got any last minute tips? Already got her ready to rock-n-roll tonite(drag pack loaded/passenger seat out/clutch fluid swapped) gonna head out as soon as I wake up tomorrow afternoon, if I can sleep at all! My left foot and right arm have been simultaneously twitching in my sleep, is that normal?
Old 10-30-2009, 01:45 AM   #11
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
To clarify things, I previously had a stock/unported ls1 throttle body and ls6 intake. It was done on the same dyno, the shop just changed locations, but being that it was done on different days and there are so many variables. I'll report back with the track results, it faired pretty well I feel against another 10sec car, so we'll find out if it has enough beans tomorrow night...
Old 10-30-2009, 01:59 AM   #12
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
It made 426/383...I've read many of the gains on an ls2, but that intake isn't even as good as the ls6. I agree more fuel needed usually equals more power. We threw 3% at it initially, which I'm suprised the stock injectors aren't maxed, to make sure it wasn't running lean then backed it off from there. WOT manifold pressure was 98kpa which I thought was strong.
Old 10-30-2009, 02:14 AM   #13
winters97gt
CF Senior Member
winters97gt's Avatar
Chris, good luck at the track! Hope the intake shows its gains at the track. Are the storms going to be out of the area by tom? We are still getting pounded down here.
Mark
winters97gt is online now   Reply With Quote
Old 10-30-2009, 04:12 AM   #14
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Thanks Mark, me too! It came down heavy last night, but has already started clearing up here with the front pushing thru. My buddy with the c5z is out of town, but I have another friend with an h/c frc with a ls7 clutch that'll be running. I know you already installed the spec, but I'll still let you know his results if ya want. I saw your results(5500rpm!) what was your 60'? The drivetrain is gonna get shocked harder with a grabbier clutch, what psi in the tires and were you slipping it?
Old 10-30-2009, 04:54 AM   #15
winters97gt
CF Senior Member
Thanks, Chris. I don't want to get your thread sidetracked. I ran a 7.67 at 95+mph in Houston of Friday with great air. 60 ft was decent with a 1.817 on the 18 inch drag radials.
On saturday at Lone Star in Sealy, I could only go high high 7.7's in the 1/8 mile, trap speed was down 2 mph, but I attribute this to extremely intense wheel hop, as I posted on your wall, and no cool down and higher DA. My 60 ft was in the 1.83-1.85 area. With my power, and the 18 inch drag radials, I should have been in the mid 1.7's both nights. Just need more strip time in a c5 with IRS.
Again, thanks for the help, please let me know how it goes on my wall. You have a stout FRC, I would like to keep this thread about your car.
Mark
Old 10-30-2009, 06:56 AM   #16
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Appreciate the concern, but I know you can't PM and we are still talking about racing vettes, plus I started this thread. I had an IRS in my mustang and the steeda pinion bushings helped wheelhop, but obviously the c5 isn't the same...just stepped outside and it's raining again, dang I feel like I'm in Seattle or London. This has to be the wettest fall here ever, may have to wait till Sun to run.
Old 10-30-2009, 08:11 AM   #17
GARY2004Z06
CF Senior Member
You have enough power to run the number. Pull your front swaybar if have not already. Focus on your launch. You will want to cut a high 1.4x to a very low 1.5x 60'. Hit your shift points. (You will probably go through the traps at 6900 rpm. Check your rev limiter.) Most important, never, ever give up.
Good luck.
As for the twitching, it's not normal unless you have epileptic convulsions.
Old 10-30-2009, 11:45 AM   #18
11sec_C5Z51
CF Senior Member
426/383 and you're saying you're running with 470rwhp LS3s???
Old 10-30-2009, 11:49 PM   #19
Interspy24
CF Senior Member
Who ported your fast? The results even with a smaller cam should definitely be noticeable. Obviously the largest gains are with the addition of good heads, but I'd with the same dyno I'd expect around 12-15rwhp.
Post your track results when you get a chance.
Interspy24 is offline   Reply With Quote
Old 10-31-2009, 10:26 AM   #20
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Quote:
The weight to avg power ratio is what defines acceleration, you can't just dyno race and compare peak numbers. He's stock geared, heavier and I might be a better driver , but I didn't actually run him (my buddies 408 put ~the same distance between him and me he said) Shaner did the port work, check new post for results
Reload this Page ported fast 90 results...
Tags
90, fast, made, ported, results
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dyno Results...F13, AFR's, LG's, Fast 90. FULTILT Performance Results 24 09-24-2005 03:58 PM
only answer this if you have TR224 cam and heads phils C5 vette C5 Tech 25 05-25-2005 08:38 PM
installing kooks 1 3/4 headers 2003silvercorvette C5 Tech 9 05-22-2005 06:19 PM
2005 C6 Z51 6-spd: Weight, dyno + drag times fair C6 Tech/Performance 54 05-11-2005 04:22 PM
afr results pdd000 Performance Results 20 08-25-2004 11:18 AM
AFR 205 DYNO RESULTS Tony M C5 Tech 40 03-19-2004 10:40 PM
Chassis dyno results ML67 C1 & C2 Corvettes 20 09-19-2001 12:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
