Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-25-2009, 10:12 PM   #1
jsbcorvette
CF Senior Member
Default New dyno numbers
Well I finally got my car back on the dyno after I installed my Fast 92 ported by vengeance racing. I used the same dyno the same tuner and ended up with a gain of 20hp and 16tq. The car made 417hp 381tq tuned before the FAST last time it was on the dyno. The mods are Lg headers,x pipe, halltech intake, LMR Stage 2 Cam kit, Fast 92 ported by vengeance, stock zo6 ti.
jsbcorvette is offline   Reply With Quote
Old 10-25-2009, 10:18 PM   #2
allngn_c5
CF Senior Member
allngn_c5's Avatar
+20 rwhp +16 rwtq post install of a Vengeance Ported fast 92 mm !! Nice gain !!
How much tweaking did the tune require?
Anyway you could show us an overlay of the old graph. Would be nice to see precisely where you picked up your additional power.
Good gains !!
allngn_c5 is offline   Reply With Quote
Old 10-25-2009, 10:19 PM   #3
0331MARINE
CF Senior Member
Support Corvetteforum!
0331MARINE's Avatar
Location: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Fallbrook CA
Send a message via AIM to 0331MARINE Send a message via Skype™ to 0331MARINE
Good results!! Good the know, im sitting around the same numbers as you were before the FAST! Now I just have to talk the wife into it.
0331MARINE is offline   Reply With Quote
Old 10-25-2009, 11:36 PM   #4
jsbcorvette
CF Senior Member
Good gains !!
He ended up playing with the air to fuel some do to the added air from the intake. I will see if I can get him to do that for me with the graph so i can post it up. Otherwise I will try to find my old dyno graph its around here some place. I forgot to add the car made the same power as a 06 ls2 with a ms4 and bolt on's.
Old 10-26-2009, 09:32 AM   #5
Quickshift_C5
CF Senior Member
This is a base C5 right, not a z06?
Quickshift_C5 is offline   Reply With Quote
Old 10-26-2009, 04:42 PM   #6
jsbcorvette
CF Senior Member
No the car is zo6
Old 10-26-2009, 04:52 PM   #7
tail_lights
CF Senior Member
tail_lights's Avatar
Great numbers and good gains from that mod!
tail_lights is offline   Reply With Quote
Old 10-26-2009, 11:10 PM   #8
CTD
CF Senior Member
CTD's Avatar
Awesome! Now what TB are you running, I see this in your comments "stock zo6 ti"?
Never mind, you meant Ti exhaust.....Sorry.
Good gains, the Airflow shows in that 4200 rpm area!
Your tuner worked it, now that little 5600rpm valley......timing maybe?
CTD is online now   Reply With Quote
Old 10-27-2009, 04:08 AM   #9
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Nice gains! I just installed my ported fast over the weekend and am waiting for it to quit raining so I can tune it and re-dyno...hope to see similar increases
PRE-Z06 is offline   Reply With Quote
Old 10-27-2009, 08:29 AM   #10
camotruK
CF Senior Member
whats your limiter? at least 6800 right? no sense in installing a cam that shifts the power band and makes peak power at 6300-6400 and not running it to 6800+...on the graph it wasnt even pulled to the stock limiter of 6600 of the LS6 cam
camotruK is offline   Reply With Quote
Old 10-27-2009, 11:29 AM   #11
ALVETTE00
CF Senior Member
ALVETTE00's Avatar
good post...always wanted to see what the FAST before and after was.
what size injectors are you using with it?
ALVETTE00 is offline   Reply With Quote
Old 10-30-2009, 04:37 PM   #12
jsbcorvette
CF Senior Member
The rev limiter is still set at 6600 I dont find the need to run the car of the rev limiter on the dyno just so I can say I got a extra 3 hp. I havent raised the rev limiter cause the car has upgraded valve springs but they are only the comp cam singles. I would like to switch them out to the dual ones before I rev the car harder. I am using the stock fuel injectors and I dont have the dyno graph yet but as stated above the car made 417hp 381tq before the fast. As far as the t/b its a stock ls2 non ported.
Old 10-30-2009, 08:31 PM   #13
sami85L98
CF Senior Member
sami85L98's Avatar
Nice, and who is LMR ? what thier stage 2 cam specs?
sami85L98 is offline   Reply With Quote
Old 10-31-2009, 10:41 AM   #14
camotruK
CF Senior Member
singles vs doubles wont make a difference in revability...singles are generally more stable assuming you have proper setup and spring pressures for your cam/valvetrain
Old 11-04-2009, 03:50 PM   #15
jsbcorvette
CF Senior Member
Quote:
Late model racecraft they have the record for fastest stock suspended lsx f body. And the specs are identical to the torquer v2 from texas speed.
Old 11-04-2009, 03:52 PM   #16
jsbcorvette
CF Senior Member
Quote:
Well I have doubles sitting at my house so thats what im gonna put in, I would rather have overkill.
Reload this Page New dyno numbers
Tags
92, cam, fast, lmr, ported, stage, vengeance
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Dyno numbers LGM LS2 Cam/LG Headers/Fast intake 460rwhp 425rwtq! LG Motorsports C6 Tech/Performance 23 05-23-2005 02:36 PM
New Dyno numbers SurfnSun C4 ZR-1 Discussion 17 06-06-2004 02:02 PM
New dyno numbers 664.6 RWHP and 589.2RWT opticZ06 C5 Forced Induction/Nitrous 43 11-26-2003 11:57 AM
New Dyno numbers, 400 rwhp and 428 ftlbs TQ, Wide Band made a difference. steve40th C4 Tech/Performance 14 07-22-2003 05:26 PM
New dyno numbers. tpi 421 vette C4 Tech/Performance 14 11-01-2002 06:52 PM
New dyno numbers for my beast! BERTZR1 C4 ZR-1 Discussion 52 10-14-2002 05:41 AM
New dyno numbers and a new top speed for me Jeffvette C4 ZR-1 Discussion 33 05-23-2002 08:00 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
