Have a question for you hard core drag racers out there. I have taken this year off from the drag strip. Last year I recorded a best of 12.33 at 105 mph on street tires. Had the following mods: melrose LTs, random tech hi-flo cats, 3.42 gears, Comp Cam 224/224 @112 LSA with.581 lift and supporting hardware, Underdrive pulley and vararam. I have since added a Vigilante 2800 stall. I am wondering if I stand a reasonable chance of breaking into the 11s if I add some good drag radials into the mix. If this is a reasonable possibility, i'm gonna go for it.
Thanks much,
Motogib
Depending on how bad your sixty foot was, you could hit your goal easy with a stall and tires.
__________________
Hi, My name is Pete...
I am a Speedaholic, I'm addicted and its taken over my life. I don't want to get better, I just want to go faster.
.... Last year I recorded a best of 12.33 .... mods: melrose LTs, random tech hi-flo cats, 3.42 gears, Comp Cam 224/224 @112 LSA with.581 lift ..., Underdrive pulley and vararam. I have since added a Vigilante 2800 stall. I am wondering if I stand a reasonable chance of breaking into the 11s if I add some good drag radials into the mix. If this is a reasonable possibility, i'm gonna go for it.
I recommend the MT DR's. Go for it..., and have fun
Thats the same set up I race with I'm now running in the 11.70's with a soft tune, I just got my Vengeance Racing Ported Fast 92 combo installed and just getting the coupe retuned and ready to race again...
Quote:
Originally Posted by motogib1
Hey Peeps,
Daniel, please share the dyno gains with the FAST and track results if/when you get it!
Not only are 11s a possibility, they're a probability.
Depending on the temps and track prep, that combo has the potential to run very low 11s all day long.
__________________
Marc 2006 Corvette 6 speed auto, Velocity Yellow, bone stock - 12.2@115.4
Now after some bolt ons and Cartek tuning - 10.7 and 127.5mph
2000 Camaro Z28 auto, NA/bolt ons only/Cartek tuning, Black - 11.8@113.6
2010 True Street LSX Challenge 13.00 Winner Save the wave!
