Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-22-2009, 11:11 AM   #1
Chicago1
CF Senior Member
Chicago1's Avatar
Default Does this sound right?? High elevation folks step in. DYNO graphs inside
With my manual I made 269/280 uncorrected 316/334 corrected(or is it the other way around???) I'm at 5200ft above sealevel with the DA being in the 8.5k range best run was 13.8@104. Mods when dynoed was intake and catback. Most C5's dyno about 250-260 up here and run low 14's/high 13's from what I see. If I convert it using this link http://www.carcraft.com/techarticles...ing/index.html it state that at sea level I would run 12.92@111 does that sound right? Most other guys at sea level with those mods seem to run about that maybe a 1-3 mph less. I have raced a few modded sti's and evo's that dyno about 350-360 to the wheels and I can inch them out but they stay right there with me from a roll for a few gears so my numbers seem about right.
here are my dyno sheets first run made 310 second was 316 nothing changed this was just to get a base run no tuning.
[IMG][/IMG]
Since these runs I have installed a ported TB, removed screen from maf, vararam air bridge, smooth coupler(I know whoopie) and relocated maf closer to TB. I want to go tune it to see what I pull but how do they numbers looks? Again real numbers for this elevation are around high 260/270 hp and 290's torque.
Chicago1 is offline   Reply With Quote
Old 10-22-2009, 11:58 PM   #2
highpockets
CF Senior Member
Support Corvetteforum!
highpockets's Avatar
Sounds OK,NA at altitude is a real killer ! I truly feel your pain,every time I see someone post a negative DA run ! Godd DA for us is Low 6000,high 5000. BTW,be careful how close you move the MAF to the throttle body.Just had a customers car come in that was hitting the throttle blade on the bridge inside the MAF at 80-100% throttle causing car to go into limp mode(idle only)
highpockets is offline   Reply With Quote
Old 10-24-2009, 02:22 PM   #3
Chicago1
CF Senior Member
Chicago1's Avatar
Yeah after I did that the car runs really lean I kinda figured that's about right. Gonna have to get a tune or something.
Old 10-24-2009, 06:20 PM   #4
Thalomos
CF Senior Member
Thalomos's Avatar
Quote:
I used this for conversion:
http://www.dragtimes.com/da-density-...calculator.php
It's nice because you can pick the day when you went to the track and it'll show weather stats for the day and give you a converted estimate based on temp elevation and humidity. I have no idea how accurate it really is.
Anyways, I went 111.23mph with my car, which converted to 112.xx on the conversion. I have a '98 with just a cat back exhaust, so I would not be surprised if your numbers are correct, you just have a good running car!
Thalomos is offline   Reply With Quote
Reload this Page Does this sound right?? High elevation folks step in
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
