Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-08-2009, 11:14 PM   #1
96mogt
CF Senior Member
96mogt's Avatar
Default Mixing Bias Ply with Radial Question
I just got a set of 16inch Hoosier Quick time pros for the rears for the track and i have a set of radials up front. I want to make sure that I have this correct, If you mix these two on the track it could throw the car around pretty good correct? What option do i have to go with, im assuming getting another tire up front that is bias ply?? Jay
96mogt is offline   Reply With Quote
Old 10-09-2009, 03:51 AM   #2
j0n
CF Senior Member
j0n's Avatar
Send a message via AIM to j0n
Quote:
new GTO spares with m&h front runners is the usual "budget" alternative.
j0n is offline   Reply With Quote
Old 10-09-2009, 04:43 AM   #3
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Agreed the faster you go and less air pressure you run, the more wobbly they get. Call me crazy, but I still run the temp tires and have been 130mph on them, it's extended heat that's bad for them. Picked 'em up at a junkyard for $65 each, worth a tenth and mph in the 1/4 too.
PRE-Z06 is online now   Reply With Quote
Old 10-09-2009, 08:03 AM   #4
Fartpipe
CF Senior Member
Fartpipe's Avatar
Send a message via AIM to Fartpipe
I think this tire thing needs to be more specific. Its not so much of a radial front bias ply rear. Yes the bias ply rear tire does have more movement because of the soft sidewall. However if you run a skinny front wheel, GTO spares, CCW's, Bogarts,Welds you can have a 165r16 or so tire thats a radial and no wondering. Its typically when you run a bias ply in the rear and a big flat tire up front. The front stays planted and has more rolling resistance. This makes the rear want to wonder and come around or feel like it does. I personally ran bias ply skinnies up front and radials. My car car felt more stable with the skinny radials and from my findings trapped higher because I had less rolling resistance on those front tires IMO.
There you have it go beat the hell out of that car and make us C5'ers proud!
Fartpipe is online now   Reply With Quote
Old 10-09-2009, 09:37 AM   #5
96mogt
CF Senior Member
96mogt's Avatar
Thanks for the info Fartpipe!! Ill be grabbing some GTO spares and heading to the track. I still have my stock gearing in the back so im thinking hopefully low 11s , i need to swap them out for some 3.90s or 4.10s. Jay
Old 10-09-2009, 12:51 PM   #6
Capthuff
CF Senior Member
St. Jude Donor '09-'10-'11
Capthuff's Avatar
4.10s
__________________
Hi, My name is Pete...
I am a Speedaholic, I'm addicted and its taken over my life. I don't want to get better, I just want to go faster.
2004 Commemorative Edition 6 spd Vert
Tuned by Doug@ECS
With Bolt-ons - 354 RWHP - 352 RWTQ - 11.33@119mph, 1.54 60'
With a 100 shot of Nitrous - 10.87@124mph, 1.54 60'
New Set up - ECS Big NA cam - LS2 heads - no port work - FAST 90/90 - 454 RWHP - 409 RWTQ.
Capthuff is offline   Reply With Quote
Old 10-18-2009, 10:47 PM   #7
RMS-MAN
CF Senior Member
RMS-MAN's Avatar
My personal experience was that I will never run full size tires up front if running a bias ply in the back. I almost wrecked my vette with ET streets out back and 245/17 radials up front. The car would swerve from side to side even tho you were holding the steering wheel perfectly still. Scary!
I agree you can mix radials and bias ply, but just always run a skinny up front.
RMS-MAN is online now   Reply With Quote
Old 10-18-2009, 10:55 PM   #8
camotruK
CF Senior Member
back in the day...my old HCI Trans Am...et streets out back...stock fronts...not a fun ride...did bogarts with ET drags out back and skinny 165 r16 radials up front and it was straight as an arrow...on my vette did 26 11.5 17 et streets with GTO skinnies with MH racemasters on them and it was very stable the whole way down the track
camotruK is offline   Reply With Quote
Old 10-19-2009, 01:52 AM   #9
97 SC Cobra
CF Senior Member
Also had this ^^^^ happen to me when I had a Mustang with stockers on the front and slicks out back. Pretty scary to say the least.
97 SC Cobra is offline   Reply With Quote
Old 11-10-2009, 12:06 PM   #10
a9secVette
CF Member
Im taking your word for it. CCW skinnies with radials and MT ET Streets in the rear. Ill post back up.
a9secVette is offline   Reply With Quote
Old 11-10-2009, 12:22 PM   #11
a9secVette
CF Member
Quote:
OK thats 2 guys Im trying this TODAY!!
Reload this Page Mixing Bias Ply with Radial Question
Tags
16, back, bias, corvette, front, inch, mix, mixing, mixxing, ply, plys, radial, radials, rear, run, skinny
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
