60ft 1.67 1/8 7.361 1/4 11.524 at 116.71mph may 24 /08 7:39pm hope to have the skinnies this fri then the complete ccw drag pack goes for a test for the first time. may want to delay this entry till after test as i hope it will be faster. might be time to put on jacket, and swing out arm on cage in.
Added you. If, or should I say when you go faster we will just move you up the lsit
Just heard about this place(My buddy Mark44 sent me)Stock 2000FRC on GY runflats with Blackwing and Corsa touring. First time out with it,5 passes with the last and best as follows:: R/T-.122,,60FT-2.115,,330FT-5.716,,1/8MI-8.598 @ 85.73,,1000FT-11.035,,1/4-13.088 @110.23 The other 4 were 2-13.6s and 2-13.4s. What a blast!!Hoping for some high 12s some day! Might try pulling the mufflers off some time and see what that does!! This was on 5/6/08
Wait for that nice cool fall air. I'm sure you will have your 12 sec pass then.
first runs will be on 6 /11 with ccw dragpack. between wheels and driver im dropping about 110 lbs., yes i lost 20lbs i the last 5 weeks.how much might i drop in quarter 2/10 maybe?
im caged and jacketed. will be seeing mtk welding tomorrow for ,harness for passenger side install. nobody wants to ride without and the trucks not a good date vehicle
__________________
1999 FRC - 11.958 @ 115.06(1.773)
ET with LS6 intake/VR-B2/GHL bullets/MGW shifter(333rwhp/334rwtq)
Now with full exhaust, no new ETs yet(348rwhp/360rwtq)
Quote:
u can finger bang your ac vents and it uploads the tune into your brain
02 coupe
ported/polished tb
222/224 566/568 112lsa
stock converter
stock manifolds
ls6 intake
cold air twin filter intake
custom cat back exhaust basically i sut the mufflers off and made it straight pipe
a4
tune by eg
315 gears
i dont know the weather and all that but here are the results
best of 5 runs
02 coupe
ported/polished tb
stock converter
stock manifolds
ls6 intake
a4
tune by eg
315 gears
best of 5 runs
