Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
TSP 233/239 Cam with Stock Heads, Dyno #'s & 1/4 Mile Time
Old 11-12-2007, 12:06 AM
Corvette Don
Corvette Don's Avatar
Default TSP 233/239 Cam with Stock Heads, Dyno #'s & 1/4 Mile Time
See mods in sig, dynoed 380 rwhp 363 rwtq on a Mustang Dyno with crappy stock 853 casting heads and ran a best of 12.6 missing 4th gear at the track today, I will get a video up of it idling.
Old 11-12-2007, 11:28 AM
ParamedicC5
ParamedicC5's Avatar
Yeah Don something isn't adding up. My guess is that car should be making into the 400rwhp range with that cam even on stock heads. You've deff got all the supporting mods. To go 12.6 at 109 dosen't make sense to me either because I run 12.60's at 114 on a stock cam. There has to be more power there. What's the lift and LSA of that cam?
Old 11-12-2007, 03:07 PM
Corvette Don
Originally Posted by ParamedicC5
Yeah Don something isn't adding up. My guess is that car should be making into the 400rwhp rage with that cam even on stock heads. You've deff got all the supporting mods. To go 12.6 at 109 dosen't make sense to me either because I run 12.60's at 114 on a stop cam. There has to be more power there. What's the lift and LSA of that cam?
It would be over 400 rwhp on a dynojet but this was done on a mustang dyno, the lift is .598/.603 112 LSA, I did a 12.6 MISSING 4th gear in the end so I would of got a 12.3-12.4, the stock heads are killing me right now, another guy that was there ran a 12.1 with a similar cam and way better heads (ported LS6's) tuned by the same guy that did mine, I would of ran more but my clutch was starting to stick to the floor. Also I am on street tires running a 2.0 60'
Old 11-22-2007, 08:51 PM
Corvette Don
Here is a video of the idle
[IMG][/IMG]
Old 11-23-2007, 01:40 AM
JDaniel
Senior Badass!
Support Corvetteforum!
JDaniel's Avatar
St. Jude Donor '08-'09
That is kinda odd. Ive ran 12.4 and 12.5's on stock heads and stock cam with stock F1 tires! Is the car pulling hard up top? Are you getting good traction?
Old 11-24-2007, 12:26 AM
blk04z
blk04z's Avatar
My cam is similar and I put down 415rwhp and 390rwtq ran best of 11.24 so far on ET streets. All my mods are in sig.
Ran 11.6 on stock tires.
Old 11-30-2007, 01:48 PM
Corvette Don
You on stock heads? You got those number from a dynojet correct? If I was on a dynojet it would of been at least 20-25 hp higher if not more, I got a 2.0 60' so that plays a role, I think I am at a higher elevation than you and I missed 4th gear so I prob lost 2-3 tenths there. And I know that Vararam you have helped you a bit.
Old 11-30-2007, 01:58 PM
mitymikec
mitymikec's Avatar
Dynojet are alot more flattering when it comes to giving out numbers. Mustang Dynos can be as much as 10-15 more conservative..
Old 11-30-2007, 08:38 PM
Corvette Don
Before my cam I got dynoed on a dynojet and put down 333, about 1 month later I got it on a mustang dyno and it was 315
Old 11-30-2007, 08:53 PM
JesseB
JesseB's Avatar
St. Jude Donor '08
i agree, you should be getting more. Man that exhaust sounds good!
Old 11-30-2007, 09:28 PM
ParamedicC5
that idle is wicked sounding!
Old 11-30-2007, 09:41 PM
mitymikec
mitymikec's Avatar
that car sounds nuts
Old 11-30-2007, 09:57 PM
JDaniel
Senior Badass!
JDaniel's Avatar
Do you have LT headers? Thats a lot of exhaust for the crappy stock GM manifolds.
Old 12-02-2007, 06:46 PM
Corvette Don
Yes mods are in sig, I have the TSP long tubes
Old 12-02-2007, 06:47 PM
Corvette Don
Yea we will see in feb when the track opes back up and I have my clutch installed
Old 12-07-2007, 11:36 PM
savage1
savage1's Avatar
sounds awesome
I bet if you put on a set of heads it will really haul
savage1
Old 12-08-2007, 07:13 PM
Corvette Don
Originally Posted by savage1
sounds awesome
savage1
I hope so, I plan on getting some AFR's or Trickflow's
To TSP 233/239 Cam with Stock Heads, Dyno #'s & 1/4 Mile Time
Old 12-11-2007, 01:40 PM
Thickraybans
Thickraybans's Avatar
My setup is very close to yours.Here's my chart before heads 401/379
And after heads 442/395
Old 12-11-2007, 02:56 PM
Corvette Don
Yea nice numbers, if I was on a dynojet I prob would have been around those numbers, I hope to be at 430 with a nice set of heads (mustang dyno)
Old 08-10-2008, 03:52 AM
Corvette Don
Just bumping this thread, I should have a long time ago, new numbers after clutch w/ updated 1/4 mile time below in sig
Quick Reply: TSP 233/239 Cam with Stock Heads, Dyno #'s & 1/4 Mile Time
