Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > Performance Results
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-01-2007, 08:10 PM   #61
Blue Angel
CF Senior Member
Blue Angel's Avatar
Ok.
Blue Angel is offline   Reply With Quote
Old 05-01-2007, 09:45 PM   #62
Mark-44
CF Senior Member
Mark-44's Avatar
Default Plan to move up! Next Week....
Bolt on List... Not able to get traction... The best 60' time 2.042 that gave me 12.867 @ 108.19 was with Traction Control On
Will try to feather the street tire take-off next week... It's raining now in the St. Louis area.
Oh, by the way ...
Thanks to ParamedicC5 for continuing to up date our times... Good Job!
Mark-44 is offline   Reply With Quote
Old 05-01-2007, 11:27 PM   #63
franny40
CF Senior Member
franny40's Avatar
12.8 @ 107 1.9 60ft. honker intake,magnapack catback, nitto 18" dr's 2002 A4 3.15 gears
franny40 is offline   Reply With Quote
Old 05-02-2007, 11:44 AM   #64
CarsRFun
CF Senior Member
CarsRFun's Avatar
i ran a 12.84 @ 111.72 99frc -w- dynatech, blackwing, tit exhaust
my dad ran a 13.1 @ 108 bone stock 2004 coupe
CarsRFun is offline   Reply With Quote
Old 05-02-2007, 12:03 PM   #65
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
00' low option coupe, A4, 3.15 , all else bone stock except:
VORTEX RAMMER COLD AIR SYSTEM
Powerloader II computer mod.
B&B TRI-FLO PRT W/SPEEDWAY TIP catback
FLP header to catback exhaust system w/ high flow cats
Best time to date w/ 275/40/17 Nitto 555R street tires @ Richmond Dragway 11/9/03 60'=1.9123, 1/8=8.0544 @89.32mph, 1/4=12.4702 @ 111.91MPH
12.4702@ 111.91 - ALLTHROTTLE&NOBOTTLE - 00 A4 Coupe - VORTEX RAMMER COLD AIR SYSTEM
Powerloader II computer mod., B&B TRI-FLO PRT W/SPEEDWAY TIP catback, FLP header to catback exhaust system w/ high flow cats
00' fully loaded Vert A4, all else stock except:
Vigilante 3000 stall converter
VARARAM induction
SLP MAF
ported throttlebody
LS6 intake
B&B TriFlo shorty headers
Corsa X-pipe ( 2 pup & main cats still on!)
3.42 gears
Baer Eradispeed 2 piece rotors (front and rear)
Z06 Calipers
Tune by Carolina Auto Masters
11/11/05 best time to date @ Richmond Dragway: 12.0879 @ 113.09 with 7.7007 1/8 @ 89.86 with a 1.6923 60' on 275/35/18 bfg drs
12.0879 @ 113.09 - ALLTHROTTLE&NOBOTTLE - 00 A4 vert - Vig 3000, VARARAM, SLP MAF ported throttlebody, LS6 intake, B&B TriFlo shorty headers, Corsa X-pipe w/ 2 pup & main cats, B&B TRI-FLO PRT W/SPEEDWAY TIP catback, 3.42 gears, Tune by Carolina Auto Masters
97' full loaded Coupe,
417 cid NA DRM/Cartek stroker (4.010B X 4.125S),
VR-1B ram air system
Ported LS6 intake
Ported TB
30lb SVO injectors
STAINLESS WORKS 3" full Exhaust,
Cartek 1-7/8 headers
3.73 gears
Rossler built stage 3 A4 w/ trans brake & Vacumn modulator
Fuddle Converter 3800 2.1 STR stall
Custom welded in 6 point Roll Bar w/swing outs. NHRA OK'd,
6-point camlocks
Local 2" Mini tub
ECS U-joint conversion driveshaft
2/24/07 best NA foot brake time to date @ Richmond Dragway: 10.8276 @ 125.14 with 6.8866 1/8 @ 99.49 with a 1.4775 60' on 275/40/17 MT ET STreet radial drs.
http://forums.corvetteforum.com/phot...7_pics0003.jpg
10.827 @ 125.14 - ALLTHROTTLE&NOBOTTLE - 97 A4 Coupe - 417 cid NA DRM/Cartek stroker, VR-1B ram air, Ported LS6 intake, Ported TB, 30lb SVO injectors, STAINLESS WORKS 3" full Exhaust, Tune by Carolina Auto Masters, Cartek 4X cam/heads & 1-7/8 headers, 3.73 gears
Rossler built stage 3 A4 w/ trans brake & Vacumn modulator, Fuddle Converter 3800 2.1 STR stall
Custom welded in 6 point Roll Bar w/swing outs by The HP Factory, 2" Mini tub
Allthrottleandsomebottle is offline   Reply With Quote
Old 05-07-2007, 03:39 PM   #66
ParamedicC5
CF Senior Member
ParamedicC5's Avatar
I updated some of the list, Allthrottle if you could put all that info into the origional format I'll throw ya up there ASAP I just don't have a ton of time to put it all together. Thanks everyone for the thank you's believe me I love maintaining this list and watching it grow!
ParamedicC5 is offline   Reply With Quote
Old 05-09-2007, 12:41 AM   #67
Mark-44
CF Senior Member
Mark-44's Avatar
Default Bolt-on's: A-4 with 2.73
Still working on traction....ran 12.840 @107.14 tonight (5-8-'07) at Gateway International Raceway, Madison, Illinois.
Old 05-09-2007, 04:22 PM   #68
ParamedicC5
CF Senior Member
List updated thanx guys!
Old 05-10-2007, 07:42 AM   #69
Cruise-In V Veteran
NCM Ambassador
Quote:
I formatted my info in my post AND added my info into your list...........change what ya want to
Old 05-10-2007, 09:39 AM   #70
Brice
CF Senior Member
Default !!!
Track : Lurcy Levis, france
Coupe 99 M6, Halltech stinger intake, Borla stringer, stock Run flats
1/4 : 12'775 @ 109 mph
1/8 : 8'283
60 ft: 1.960
Brice is offline   Reply With Quote
Old 05-16-2007, 01:08 AM   #71
ParamedicC5
CF Senior Member
sorry guys it's been a while I'll update the list tonight!
Old 05-16-2007, 04:33 PM   #72
ParamedicC5
CF Senior Member
Quote:
LOL you had me worried for a second, I went to update it and noticed it was mostly done....! No worries thanx btw work has been crazy I appreciate the help!
Old 05-19-2007, 02:51 PM   #73
ParamedicC5
CF Senior Member
I sent an email to the site admin to try to get this list sitcky'd like the C6 list. Just wanted to update everyone.
Old 05-22-2007, 08:23 AM   #74
Mark-44
CF Senior Member
Mark-44's Avatar
Default Sticky
No more confusion. Thanks.
Bolt-ons update.. Tuesday Test and Tune, Gateway International Raceway, Madison, Illinois, May 22, 2007.
12.749 @ 108.38 with a 2.73 gear.
Old 05-24-2007, 01:01 AM   #75
madmatt9471
CF Senior Member
madmatt9471's Avatar
Location: Palmdale, Ca----- 1/4 10.34 @ 135 MPH - 701RWHP & 582RWTQ
This is good!
I will post mine when the motor is done and it reaches the track!
Thanks,Matt
__________________
madmatt9471 is offline   Reply With Quote
Old 05-24-2007, 05:55 PM   #76
alari
Junior Member
alari's Avatar
Estonian fastest C5 !
97 Procharged 5 psi Procharger P1SC 5psi (stock pulley) w/twin air-air intercoolers
Stock 346ci LS1 around 10:1
Lingenfelter 212/218 camshaft
Lingenfelter 66cc Stage 1 LS1 heads
Lingenfelter High-Flow Fuel Pump
36# Injectors
1.85:1 Rockers
3.73 gears
2400 Pro-Torque Converter
Breathless Stepped 1-7/8 Long-Tubes
2.5" Dual Exhaust with X-pipe and 2.5" Dynomax Ultraflow Ovals
11.077@127,5 1,69 60'
My 11,2 race vs 2006 SRT -10 Viper
http://allikas.com/race/mov/viperus2.AVI
PS. Estonia is a small country in North Europe
alari is offline   Reply With Quote
Old 05-25-2007, 09:23 PM   #77
blk04z
CF Senior Member
blk04z's Avatar
Send a message via AIM to blk04z
Update
11.241@121.09 1.660 sixty
blk04z is offline   Reply With Quote
Old 05-29-2007, 08:35 PM   #78
ParamedicC5
CF Senior Member
The list has been updated, it's great to see how big this list is getting. Lets keep it going!
Old 05-29-2007, 08:53 PM   #79
electronbluec5
CF Senior Member
electronbluec5's Avatar
Send a message via AIM to electronbluec5
I think you must have missed my post on page 3. Here's the info again.
11.79 @ 121.5 - electronbluec5 - 2003 Z06, TFS 215s, Vengeance 224/228 113lsa, Fast 90/90, Vararam, Stainless Works LTs, Spec 2, DRs
Greg
__________________
2003 Electron Blue Z06
Mods by Vengeance Racing: LS7 440ci Stroker, Trick Flow 235cc heads, Vengeance Cam 262/270 113lsa, Harland Sharp Roller Rockers, Fast 90/90, Kooks 1 7/8 LTs, Kooks 3" Catted X, Motion Double Roller Timing Set, Pfadt Coil Overs, Pfadt Sways
Other Mods: Wilwood 6 Piston Front 4 Piston Rear Setup, Hurst Billet Plus shifter, Cat Delete, Vararam VR1B, Stock Ti Axle-Back.
609 rwhp 552 rwtq
electronbluec5 is offline   Reply With Quote
Old 05-30-2007, 09:08 PM   #80
Robert56@RNS
Collections Hold
Robert56@RNS's Avatar
Default Z06 Fast List
Here's the CorvetteForum Z06 Fast List that has been going for a few years, for those that may not be aware and a sticky in the Z06 section. We have added a few new catagories, so those with a Z06 please add to this list also. If you like you can copy this list into your ongoing list. I will check out your Z06 additions for any that may be missing in the Z06 section. Thanks for doing a C5 list, as I know how much work and dedication it takes to keep on top of things.
Maybe we could add this list as a sticky here also? as the Z06 section doesn't allways get the racers checking it out.
Z06 Fast List
Robert
Robert56@RNS is offline   Reply With Quote
Reload this Page Official C5 1/4 Times List
Tags
14, 2003, 440ci, c5, corvette, d1, fartpipe, forum, haltech, ls7, mile, procharger, racing, rammer, vengeance, vortex, vs, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[OFFICIAL] Airport Cruise-In RELOADED Lord Odin Great Lakes 99 07-21-2005 11:09 PM
Kens Weekly Newsletter - MORE NEW NEWS! - 4/22/05 Ken Fichtner Ken's Newsletters 10 05-04-2005 09:23 AM
CARTEK C5 PIG RUNS 10.99@125.7 MPH my00c5 C5 Tech 105 10-09-2002 06:16 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
