C5-R/9 sec/2000 Coupe Tear Down - Results Inside!
All you guys that know me are aware that I share all my info.:
Setup built 2003 Designed and installed by Dan Bills Owner Finish Line Performance, Naperville, Ill. 630-717-0824. Engine (427 C5R) by Scott Fulkerson owner of Midwest Engine Tech, Mokena, Ill. 815-464-9490. 4L60E Tranny by Chuck Johnson owner of Finish Line Transmission in Wood Dale, Il. 630-350-7776. 3.73 Rear End by Phil Rickard owner of Dynotech Engineering in Fort Wayne, In 260-407-5455. Driveshaft by Doug at East Coast Supercharging 609-752-0321.
Here Goes:
Car has 31,991 orig. miles, 400 1/4 mile runs total.
427 Motor has 8895 street miles and 200 runs.*
Transmission, Rear end and Drive shaft have 3,574 miles and 100 runs.*
*including the 2006 Hot Rod Magazine drag Week event during which I drove the Vette 1855 miles in a week sometimes 10 hours on the road PULLING a 1600lb trailer running 9.80's at each dragstrip!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Due to new technology in the heads and valve train areas Dan Bills and I decided to "UPGRADE" the set up and push the 9 sec. times down to high 8's.
Tear down results:
Motor: NO SIGNS OF WEAR!
Heads & Valve Train: ONE COMP HYDROLIC LIFTER SHOWED SIGNS OF A ROLLER PIN STARTING TO FAIL (resulting in the decision to replace lifters each year and limit risk)!
Transmission: SHOWED NO SIGNS OF WEAR! (Will still teardown and inspect yearly)
Rear End: SHOWED NO SIGNS OF WEAR! (Will still tear down and inspect yearly)
Suspension: After 7 years needed 2 upper control arms and all the tie rod ends (What do you expect after doing all those WHEELIES?)
Incredible Results of GREAT QUALITY work if you ask me!!!!
JR
Here Goes:
Tear down results:
JR
