Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
c-5 automatic stock 0-60 and 1/4 times?
Old 05-20-2006, 08:14 AM
07 Indy Car
07 Indy Car's Avatar
2023 Corvette of the Year Finalist - Unmodified
2022 C7 of the Year Winner (unmodified)
Default c-5 automatic stock 0-60 and 1/4 times?
whenever I research my car year, they are always listing results with a 6-speed trans. I want to know what times a 98 c-5 automatic with the performance axle ratio is capable of. Both 0-60 and 1/4 mile. Thanks
Old 05-20-2006, 06:08 PM
DBN
DBN's Avatar
My car (stock) did 2.3-2.2 in 60ft and 8.8-8.9 in 1/8 which is a high 13 in the 1/4.
Old 05-20-2006, 09:42 PM
WALLstAL
WALLstAL's Avatar
St. Jude Donor '05
Mid 13's
Old 05-20-2006, 09:58 PM
CRV3TT3
CRV3TT3's Avatar
its bound to be better than that my stock '87 ran a 13.87@98 with a 1.95 60ft
Old 05-21-2006, 08:25 AM
Blow Torch
Blow Torch's Avatar
SB
Just in case you're loking for 0-60mph, My wife's auto with 2.73 (not your 3.15) ran a best of 5.18 before we started "tweaking"
Old 05-23-2006, 01:18 PM
JoshVette
JoshVette's Avatar
My 02 A4 coupe, with 3.15's stock, and street tires ran a 60 2.1 and 1/8 8.7 at 83mph.
don't have 1/4 times, but that's roughly 13.4-13.5 in the 1/4.
After vararam I ran 1/8 8.53 at 84mph.
Old 05-23-2006, 02:23 PM
MassaRusty
MassaRusty's Avatar
Originally Posted by BOTTLE FED
SB
Is the 2.73 faster in 0-60 than the 3.15? I would immagine that the 2.73 gets pretty close to 60 in first gear. I know that the 3.15 has to shift before then. I would think that the lack of shift would be a big difference with the torque management.
Old 05-24-2006, 01:31 PM
c5chines
c5chines's Avatar
Default Times...
The 3.15 is noticably quicker than the 2.73 axle. With just a open element air cleaner you should be low 13's. If everything is perfect you might even eek into the 12.99 range. the stock C5 air cleaner strangles the LS1. Chuck.
Old 05-25-2006, 10:08 AM
Beast
Beast's Avatar
best of 13.33 all stock, bunch of 13.4s
with stinger intake and catback, best 13.1 105mph, with a bunch of 13.2s
Joe
Old 05-25-2006, 10:40 PM
franny40
franny40's Avatar
i ran a 13.2 @ 106 2.0 60', i have a callaway honker intake and used the 18" dr's off my z28. i was hoping for better times, but it was close to 100 degrees that day, so i hope with some cool weather 12's are possible
Old 05-26-2006, 08:52 PM
DeFormula
DeFormula's Avatar
'99 coupe, Bone Stock down to the filter and run flats...
13.20 and best MPH 107.63. 2.73 auto.
Old 05-28-2006, 06:00 PM
stanger383
stanger383's Avatar
St. Jude Donor '09
3.15 gears and bone stock a4 13.13 @ 106.28 WITH 1.99 60'
Old 05-29-2006, 03:35 PM
ebubman
ebubman's Avatar
we had an 87 also; the c5 gives one a bigger push in the sotp! bub
Old 05-29-2006, 11:58 PM
SphyNxXx
SphyNxXx's Avatar
Ive only made 1 pass in my 98 C5 (a4, 3.15) and it was a 13.66 @ 101. The night of the pass was pretty warm and humid. Even with a 180* tstat, my engine temp was at 225* at the time of the pass. The only mods on the car was Borla Stingers, 180* Tstat, Cold Air Screens, and Falken GR-Beta Tires. I know it has plenty more in it, but it was too crowded and hot that night to make any more runs. I'll probably go back once it cools off.
Old 06-01-2006, 02:51 PM
03Topless Snake
03Topless Snake's Avatar
My drove his 99 Bone stock C5 A4 w/ 3.15 rear end(stock) ran best of 13.4 @ 104mph.
If I get an "open air" filter will I need a tune. Sorry I'm a newb to the
Ls1 world. I bought the car from my dad this week and I want to do some basic mods. Oh the 99 has just 7,900 miles on it. Still bone stock
Old 06-05-2006, 12:11 AM
Sammy_C5
Sammy_C5's Avatar
phast baby phast
Old 06-19-2006, 10:05 AM
Polar Jet
Polar Jet's Avatar
Pretty identical to my 01 A4.
The 01 and up C5's are a little quicker than the 97 to 00's. I would wager that yours would run 0-60 in a couple ticks over 5 seconds and do about 13.5 in the 1/4 mile.
To c-5 automatic stock 0-60 and 1/4 times?
Old 06-19-2006, 11:32 AM
Raped-Ape
Raped-Ape's Avatar
my 2000 coupe 3.15 rear went an 8.41@86 with a 1.90 60ft . all stock down to the paper filter and runflats.
Old 06-23-2006, 11:49 AM
DragMan
DragMan's Avatar
Cruise-In VII Veteran
mid 13s depending on air quality & hook.
Old 07-08-2006, 03:34 PM
VLVETTE
VLVETTE's Avatar
2004 A4 3.42s Vararam Runflats
Quick Reply: c-5 automatic stock 0-60 and 1/4 times?
