should I use the vette panel adhesive to fill new seems
well I got my car back and have to fill the seems on the new fender what should I use as a filler over the bonding strips exposed line ,, fiberglass , vette panel adhesive ,, both
Either way will work fine. Some people like to grind out along the the panel lines and lay in some fiberglass mat and finish with vpa. I have been redoing fender seams on C3’s with just vpa for many years and never had any problem. I did my own car that way.
Yeah i used VPA, i took a mini disc grinder at an angle to remove and bevel the pieces to remove as much old crud as possible to have a fresh and better bond. shaped it back and finished with a light coat of regular filler for final sanding and primer.
Received 1,460 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
What is your outcome?
Do you want an NCRS paint job or not
If not v groove them and you can fill with VPA
If not you can leave them
