L98 hood over an lt1
I am having trouble finding a decent late c4 hood. Has anyone tried the 85-89 hood on a 95? Was the AC press or an issue? How much work to make it fit?
YES...using a hood from a tuned port is an issue due to the area above the ac compressor is the problem. I have modified the hood to fit before where I had to CAREFULLY cut out the inner structure form the old hood and splice/section it into the used hood.
I do a lot of fiberglass work so it was not that big of a deal...so it depends if you know how to do bodywork.
I believe the mounting studs on the inside for your headlight supports are different also.
DUB
New hood option
I found a place about 6 hours away that makes the GM restoration hoods but the are three times what a good l98 hood goes for. The car is a project and used for road trips. I see the difference as new seat covers and foam. I've done bodywork but not on fiberglass.
I'll read up on your other posts but thinking I like the option to put the $ into two improvements rather than one. Thanks Dub
Sending you a PM.
DUB
