Door jambs
The hood scoop was gel coat. Where it was bonded/inlaid I removed material down to bare glass. I used vpa to bond and vpa 870 to fill. Where ever there is body filler I removed material down to bare glass. It appears that body filler is over gel/primer. It does appear to overlap which it does. However After sanding everything smooth the body filler was not on the black area of scoop. I did not take a pic of that step.
I was concerned that filler was applied on a primer...which is not the correct way of ensuring a good bond for a long time.
DUB
DUB
Ok I have been sanding the high build epoxy primer with 220 on my long board . It has done it's job and hidden a lot of imperfections. I will shoot a couple more coats of primer . Should I shoot a med build or another high build at this point. Would 400 wet after primer be sufficient for sealer ?
As I often times mention...TEST IT...shoot a small something laying around and sand it and shoot the sealer on it and see what happens.
DUB
