where to buy
where to buy
hi,Anybody know where to by fiberglass hood scoops that fit a stock c6 corvette,ive tried dozens of sites but seems they all want to sell the entire hood.Or they have crappy ricer looking scoops.Any connections would be deeply appreciated .
Some hood already have a lot of flex/twist in them...and if a scoop is bonded so no seam is seen...and depending on the scoop itself...a crack can appear over time if the owner is not careful in raising and lowering the hood. You have engine heat and sun beating on this hood...and if the inner structure was not made to aid in preventing any flex so a scoop can be installed....that is when buying a hood that has the scoop made into it is best.
If you can not find one you like...like many of my customers also run into....sometimes they will get different scoops and have be make the one they want...and I can tell you...depending on what needs to be done to achieve this...this is time consuming and QUITE expensive....but they will have what they want and it being the only one out there.
Custom work is NOT cheap...and NOT writing that you are CHEAP...I am just letting you know that if you have someone make one for you...you might choke when they tell you how much it is going to cost.
DUB
custom hood
When it comes to hood...from what I have experienced through the years. Adding a scoop to an existing hood can be quite challenging. I KNOW what I am doing and regardless of that fact. If internal structures and or structural integrity of the hood has to be compromised to add a scoop...then the owner is notified and if they still choose to "look cool" and weaken their hood...it is ALL ON THEM...NO GUARANTEE/WARRANTY.
DUB
DUB
Not sure on what you want style wise but have you looked at Jegs or Summit racing ? ACI in Sylvania Oh are good people and may be able to sell you just the part you need. I just stopped there Thursday. May be worth a call.
thanks for leads.Ive loked at jegs and summit racing,not looking for something that is too high.I'll try those other sites,you mentioned.Hood scoop has to have a close profile on the bottom to reasonably fit on hood.Thanks
