building a buffing tool
Hi all,
i have a general purpose motor sitting in the basement collecting dust. It's a 110v 1/2 or 3/4 HP motor with a 5/8 keyed shaft. Pretty standard all purpose motor. I was thinking of mounting a large buffing wheel to the shaft, bolting it to a bench and using it to buff the stainless flash chrome trim on my 64.
First thing is I don't know what to call the clamping mechanism needed to hold the buffing wheel in place, and where to get them. I think Graingers call them mounting flange, but they don't seem to list them as accessories. Also, the shaft I have is not threaded, just keyed.
Next, I will need to know what type of mild abrasive to use.
Any advice?
Thanks,
Greg
Any advice?
Thanks,
Greg
I do not know if it will work. Mine is threaded and allows the buffing wheel to be secured to it. It would seem like a sleeve will need to be installed and then having an Allen head set screw or two to lock it on so it will not turn is possible.
As for what to use or buy...I can not remember...but you can go on-line and find companies that will tell you what to use for your intentions. EASTWOOD is a good starting point. You may find that you will need more than one buffing wheel....much like buffing paint...it is not all done with one buffing pad...that is if you are wanting it done correctly...that is. Getting stainless steel and aluminum RIGHT is FUN.
DUB
DUB
Caswell sells the wheels and polishing compounds.
http://www.caswellplating.com/buffing-polishing.html
Greg
