What do I use to paint under the hood?
In the past I've just used Krylon Satin out of a spray bomb. Is that OK or should it be spray gun sprayed with something - like maybe Epoxy primer, then a paint?
If the car is a Non-SMC car...I apply black gelcoat. This will make is absolutely certain that oil and "what-have-you" that gets on the underside of the hood will not penetrate the fiberglass and damage the exterior paint. After I gelcoat it...I then apply a black epoxy primer and then either leave it or apply a semi-gloss/satin black single stage paint that I mix on my paint machine.
If it is a SMC hood...I apply the black epoxy and either leave it or apply the same single stage semi-gloss/satin paint.
DUB
DUB
DUB
DUB
