Paint/Body Corvette Materials, Techniques, and How To
Fiberglass Body Prep
Old 05-13-2012, 05:21 PM
8valve
Support Corvetteforum!
8valve's Avatar
Default Fiberglass Body Prep
I have painted all my restored vehicles for 40 years including 4 Vettes. But now I am faced with a issue I have never dealt with.
I bought a 73 that I am now restoring. The previous owner started to strip the car. On the front fenders he sanded thru the gel coat and fiberglass is exposed. You can lay your arm on the fenders and feel the fiberglass itch your skin. What is the proper way to cover the fiberglass and get a good substrate for 2K and finally Base/Clear.
Many Thanks
8Valve
Old 05-13-2012, 05:44 PM
porchdog
porchdog's Avatar
epoxy primer.
Old 05-13-2012, 07:30 PM
8valve
8valve's Avatar
Originally Posted by porchdog
epoxy primer.
Thank you, we seem to be thinking the same way. My thought was PPG Epoxy Primer, 2 coats. Then PPG 2K high build primer, finally base/clear.
Do you agree ?
8Valve
Old 05-13-2012, 08:56 PM
markids77
markids77's Avatar
I used all epoxy on my 1977. It was expensive, but I needn't worry about multiple products becoming unhappy with each other over the years. BTW, there was no gelcoat on your 73 from the factory, just primer and color... no clear.
Old 05-14-2012, 07:04 AM
porchdog
porchdog's Avatar
spi epoxy is sandable. it is all i use for primer . the ppg epoxy is not as good as it use to be.
Old 05-14-2012, 05:00 PM
8valve
8valve's Avatar
Ok, thanks for the info
8Valve
Old 05-14-2012, 05:23 PM
tjhphoto
tjhphoto's Avatar
For the next step: would you do bondo work before or after the primer?
Old 05-14-2012, 07:05 PM
zwede
zwede's Avatar
Some say before, some say after. Both have resulted in good looking paint jobs.
Old 05-14-2012, 09:03 PM
markids77
markids77's Avatar
My answer to that is "yes". You'll likely have some major repair that is quite obvious before you seal, and some smaller repairs that become evident after you start the blocking process. Go with the flow, and both ways are "OK".
To Fiberglass Body Prep
Quick Reply: Fiberglass Body Prep
