Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Paint/Body Corvette Materials, Techniques, and How To
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2012, 05:46 PM   #1
vetternr
Junior Member
Support Corvetteforum!
Default Paint / Fiberglass damage
Does anyone have any expert advice or experience about repairing a paint damaged area on a C3 ( 1972 ) rear deck near the spoiler ? I was unfortunate to have left a towel with some hydraulic jack fluid on it. The paint originally bubbled up ( an area of about 1/2 square foot ). It has widened in the last 6 months or so to an area of about 1 square foot. I dont know for sure what to do about it as it might be down to the fiberglass ? Should I sand it down, paint strip it with a chemical stripper and what about if it got into the fiberglass ?
vetternr is offline   Reply With Quote
Old 02-23-2012, 09:40 AM   #2
Dave Tracy
CF Senior Member
It sounds as though the oil is wicking through the glass. I have seen several comments on contaminated glass being cleaned with blue Dawn dishwashing soap. You will have to sand off the paint beyond the bubbled area and wash it with the soap, let dry in the sun and repeat several times. If unsuccessful, the glass may need to be removed and replaced. Someone else will likely chime in with other ideas. Sorry to hear of your misfortune.
Dave Tracy is offline   Reply With Quote
Old 02-23-2012, 02:35 PM   #3
zwede
CF Senior Member
zwede's Avatar
Getting oil out is a long, slow process. You need to get the paint off first. Chem strip it. Then it needs to sit in a warm environment. Best is out in the sun on hot days. Every time you see oil on the surface, wipe it off with lacquer thinner. It can take weeks until it stops.
zwede is offline   Reply With Quote
Old 02-25-2012, 10:14 AM   #4
porchdog
CF Senior Member
porchdog's Avatar
first remove the paint with razor blade and sandpaper. using a hair dryer heat the area some then apply talcum powder . if there is oil present it will be drawn into the talc much like speedy dry. when you feel the talc is no longer absorbing anything wash with dawn soap and hot water. it may take several times to get it. finish up with water base wax and grease remover the epoxy .
you need to disperse the oil . any solvent will dilute it and embed it further into the glass. that is the worst thing you can do.
porchdog is offline   Reply With Quote
Reload this Page Paint / Fiberglass damage
Tags
area, body, corvette, damage, feet, fiberglass, oil, paint, square
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
