Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Paint/Body Corvette Materials, Techniques, and How To
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2012, 05:43 PM   #1
redman76
CF Senior Member
St. Jude Donor '09
redman76's Avatar
Default Adjusting Front Bumber Cover on '76
Hey guys, I live in the C3 section but wanted to ask the body experts how to properly align the front bumper cover on my '76. It's already painted and mounted, so I don't not want to do anything requiring a cover repaint. When I replaced the cover (pulled and had repainted because of large paint chip), I removed all the bubba'd rusted bolts holding it on. I tried using the proper t-bolts, but they were not long enough, so I used longer stainless hardware to fasten. Seems like I remember there were rusty washers/spacers that I removed too.
The bumper never fit very well to begin with. The body lines do not match up well and the cover seems to be spreading out so it is not flush with the body surface. What is the trick? Do I use spacers to get the gaps consistant? Do I make the holes bigger to give me wiggle room and push cover even with surface and tighten? Am I going to need to pull to cover off a hundred times until I get everything lined up properly? Any advice would be greatly apprecaited . . . what are your tricks?
I'll try and post some pics tonight.
redman76 is offline   Reply With Quote
Old 01-27-2012, 10:19 AM   #2
redman76
CF Senior Member
St. Jude Donor '09
redman76's Avatar
Anybody?
Old 01-28-2012, 01:26 PM   #3
markids77
CF Senior Member
I just finished installing my 77 bumper yesterday. If it is like your 76 there should have been formed sheet metal stiffeners with 10-24 screws sticking out of them at each hole location. The stiffeners apply more even pressure between the screws and help keep the lines at the joint straighter and tighter. I started in the center and worked the fitment out to each end one section at a time. I have my headlight buckets out, so access is easier... it's worth the time to drop them if they're in place on your car! My fit is not exact either but I did get it OK in about an hour's worth of playing around. If you no longer have the OE stiffeners I would invest in a set for sure.
markids77 is offline   Reply With Quote
Reload this Page Adjusting Front Bumber Cover on '76
Tags
76, body, bumper, c3, corvette, cover, front, gap, mount
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
