Paint/Body Corvette Materials, Techniques, and How To
Outer window trim on an '81...
Old 11-20-2011, 03:47 AM
VeroL81
VeroL81's Avatar
Default Outer window trim on an '81...
I'm finished applying 2K primer on my '81 , except for two areas where I need to remove trim - the outer door and the back window.
Regarding the door trim - does that just pop off with a screwdriver?
Regarding the back window trim - ya think I could just drive to a car window shop and they'd pop it off?
Thanks for any input!
Alan K.
Old 11-20-2011, 11:19 AM
CF6873
CF6873's Avatar
for the rear glass molding you need a KD tool #2038 Or you could pay a glass shop to remove it for you.
Not sure about 81 but the earlier C3s had the outer door molding attached with phillips headed screws right thru the felt. You have to search a little to find them.
Old 11-20-2011, 09:46 PM
VeroL81
VeroL81's Avatar
Thanks for the reply. Got the stubborn trim off with the help of my Dremel tool... Gonna install the new trim tomorrow.
....Alan K.
To Outer window trim on an '81...
Quick Reply: Outer window trim on an '81...
