Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Paint/Body Corvette Materials, Techniques, and How To
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-29-2011, 12:17 AM   #1
69SSC5
CF Senior Member
69SSC5's Avatar
Default how far do i sand down the paint
started on sanding my 88 C4 today,,, man block sanding is alot of work... i sanded off the clear coat, sanded off the stock red paint... under the red paint is a dark grey color then under that is a light grey (i assume that is primer)... do i sand past the light grey or do i just sand away all the dark grey till its light grey....
i am using a block and 80 grit paper
URL=http://imageshack.us/photo/my-images/638/c4paint.jpg/]Click the image to open in full size.[/URL]
69SSC5 is offline   Reply With Quote
Old 07-29-2011, 09:10 PM   #2
markids77
CF Senior Member
That light gray stuff appears to be raw glass. Stop sanding when all the red is gone. then try lacquer thinner and a coarse Scotchbrite pad to see if that will take off the dark gray. If you continue to sand 80 grit untill all is a uniform light gray it looks to me like you'll have trouble with making the glass thin in spots. What are you using for a block? The reason I ask is if your sanding technique is good, the factory panels are really wavy since all the light gray is not leaving at the same rate. They're never perfect from the factory, but my experience is they ought to strip more uniformly.
markids77 is offline   Reply With Quote
Old 07-29-2011, 09:18 PM   #3
69SSC5
CF Senior Member
69SSC5's Avatar
Im using dura blocks. I don't really have a technique I was just sanding. Is there a proper way to sand to remove paint? First car I've sanded and painted
Old 07-29-2011, 09:46 PM   #4
markids77
CF Senior Member
The best way to remove paint using sanding is to try and remove it all at approximately the same rate meaning trying to go to all the edges, in all the curves and as far into all corners as possible evenly and smoothly. Long sanding strokes carried all the way to, but not lapping over the edges of panels are most effective and easiest to keep uniform. You must remember that the glass substrate is soft as well, and if you press harder or sand longer/less in any spot you will remove panel thickness as well as paint. This will make getting things straight as you prime and reblock(yes you will have to sand the entire car two, three or possibly more times again before you apply color). On you hood I would now carefully try and remove just the red from those areas it is still visible and hope for the best when you prime/resand. For the rest of your removal pay close attention to how uniformly the topcoats are coming off ( you'll be able to tell if you look closely) and modify your technique to getit as close to even as possible.
Old 07-30-2011, 02:26 PM   #5
69SSC5
CF Senior Member
69SSC5's Avatar
thanks for the tips... The goal is to get all the paint and primer off and get down to EVEN bare glass, is this correct? i also read that i am supposed to seal the bare glass right away?
Old 07-30-2011, 04:11 PM   #6
CF6873
CF Senior Member
IMHO there is no reason to remove the primer on a C4 unless you want to apply polyester filler to the whole car to make it "show car straight". If you just want to block it and make it better than it was you can apply urethane primer surfacer directly on top of the factory primer and block that as needed.
Blocking with 80 grit on the bare glass is going to make some deep scratches that are going to need filled by polyester filler prior to applying primer. Most paint manufacturers recommend sanding with 180 or 220 before priming.
I would use 180 to strip it and then apply the primer and then block the primer. This will save you quite a bit of work.
Good Luck
Craig
CF6873 is offline   Reply With Quote
Old 07-30-2011, 04:59 PM   #7
69SSC5
CF Senior Member
69SSC5's Avatar
Good Luck
Craig
the plan was to try my best at a show quality paint job, i was planning on doing a poly filler (some spots on the car needed it already anyway) on the entire car and removing almost all the body panels for final prep before painting. i have alot of time on my hands right at the moment and i dont mind the work out (sanding that is)
Old 07-30-2011, 05:29 PM   #8
CF6873
CF Senior Member
I now understand what you want to accomplish, but you still do not want to cut into the glass with 80 grit. If you look at the directions on most sprayable poly fillers you will see that 180 -220 and finer is recommended.
Old 07-30-2011, 10:56 PM   #9
69SSC5
CF Senior Member
69SSC5's Avatar
I will be buying 180 or 220 on monday and use that to remove the primer. Is it ok to use the 80 grit to strip off the clear and some of the red paint? Also I noticed that the primer seems to be alot thicker in some areas than others, is that normal?
Old 07-30-2011, 11:21 PM   #10
markids77
CF Senior Member
Broken down to simple terms all paint prep consists of is making progressively finer scratches in the body panels, then filling them and repeating until the topcoat is so smooth the scratches no longer show to the naked eye. It is OK to start with 80 grit, and I always try and use the most coarse paper which will not ruin the job at hand... it saves time and energy to cut as aggressively as practical early in the paint removal process.
Even the factory uses a "build" primer to eliminate waviness in new car panels, so yes some variance in thickness is normal. If your car has already received a professional strip/refinish then the thickness of primer substrates can be greater than original as well... fiberglass "moves" as it ages and can get wavy due to environmental exposure, chemical changes and careless prep; all of which require more "remediation".... either thicker primer coats, or actual body filler/resin application followed by a surfacer.
Old 07-31-2011, 11:24 AM   #11
CF6873
CF Senior Member
Like Markids stated it would be OK to use 80 but you will want to eliminate the 80 scratches with something finer prior to any poly or urethane filler.
Old 08-12-2011, 11:02 PM   #12
69SSC5
CF Senior Member
69SSC5's Avatar
ok i finally got all the clear coat and red paint sanded off of the car with 80 grit paper and dura blocks. now how do i get rid of the dark grey color primer? i tried 3m pad and laquer thinner but that didnt do much.
Old 08-13-2011, 09:24 AM   #13
markids77
CF Senior Member
220 grit wet is a good next step if thinner won't take it off. You do have to smooth the 80 grit scratches anyway, and my personal opinion is 220 grit scratches are unlikely to telegraph through at least 2 coats of fill priming sanded progressively finer, and they give a good "tooth" for the first coat to grab onto. Again, be careful with your technique, and I would not stress too much about leaving some small patches of factory primer in the low areas on the car.
EDIT: Be sure to let the car dry preferably 48 hours before applying paint after wet sanding... the bare glass will soak up some of the water. And yes... please seal the bare surface as soon as practical after sanding it raw.
Old 08-13-2011, 09:05 PM   #14
69SSC5
CF Senior Member
69SSC5's Avatar
what should i seal the bare glass with?
Old 08-13-2011, 09:56 PM   #15
markids77
CF Senior Member
I am using a catalysed epoxy primer as the only base under paint on my 1977. It seals well but does not build very rapidly, but my car is pretty straight after I did all the body repairs required. I recommend you choose a paint supplier now, and follow that manufacturer's techline recommendations as to which product should be applied in what sequence for best result. I see you live in Kalifornya, so what is legal here in Georgia is probably not in LA. I suspect you will be required to purchase low or no VOC refinish products... to almost cetainly include water borne color coats. I can still purchase "traditional" paint systems here, so my experience will differ.
Old 08-14-2011, 12:20 AM   #16
69SSC5
CF Senior Member
69SSC5's Avatar
Yeah I need real paint not the stuff they sell here in cali... im going to order it online and have it shipped to my fathers house in texas. I would like a thick primer, one that hides imperfections well. Can u steer me in the right direction as to places to start looking or as to which manufacturer to choose?
Old 08-14-2011, 10:11 AM   #17
markids77
CF Senior Member
I have no experience with mail order materials so I can't advise you there....I like Sherwin Williams products myself... get them at the local NAPA. Perhaps another member has ordered their stuff online and had the job turn out well?
Old 08-14-2011, 05:17 PM   #18
zwede
CF Senior Member
zwede's Avatar
Quote:
PPK K36. It's a 2K Urethane primer with some build to it.
zwede is offline   Reply With Quote
Old 08-14-2011, 10:15 PM   #19
CF6873
CF Senior Member
If you want a substantial filler I would use Slick Sand by Fiberglass Evercoat. It is a sprayable polyester filler.
You will need a spray gun with at least a 2.0 fluid tip to spray the stuff but it will fill small waves and scratches. It is also quite a bit less costly than urethane primer.
After this is blocked you can just apply sealer and then paint.
Old 08-18-2011, 02:14 PM   #20
69SSC5
CF Senior Member
69SSC5's Avatar
ok im frustrated at this point... i tryed to sand the dark grey primmer off with 220grit but no luck, so i switched to 180 gritt, no luck... this primer is thick as all get up and doent want to come off.... ive spent 30+ hours hand sanding this car and now im tired (much respect to those that due this for a living). im thinking about breaking out the DA sander and goen at it with 220 grit on the DA. what do you think,,, how do i get this dark grey primer off....... if i create some waves in the glass will a thick high build primmer fix the waves?
Reload this Page how far do i sand down the paint
Tags
block, car, corvette, dark, fiberglas, fiberglass, form, grey, grit, hood, lancaster, paint, remove, sand, sandin, sanding, scottbrite
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
