How to correct the alignment?
Hello everyone,
I have the right "front fenders" which is lower than 1.5 cm than the left
NO ok
ok
below, another angle:
I first look if it was a door problem, but are identical on both left and right!! As you can see from the photos:
the following photos shows that if we fix the "windshield header molding corner" the problem is not with the door .....
(I made a small line at the edge of the front fender)
do you think the problem would come from a bad bonding?
where from the incorrect mounting bracket radiator?
Perhaps you would any other ideas .......
I felt completely removed the front end "....
I would absolutely realign all !!!!!!!!!!!!
thank you,
david
NO ok
ok
thank you,
david
