Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2010, 11:02 AM   #1
bj33813
CF Senior Member
Default removing paint spatters from 3M clearbra
Yo-yo in a truck ahead of me was busy chatting on his cellphone, or texting, and hit the center median causing junk to fall off the back, some of which apparently was paint.
Got a small amount of white paint spatters on the nose and driver side fender top, and as the car is LeMans Blue, it stands out pretty good.
Tried gasoline, paint thinner, even acetone and nothing softens or removes any of it.
Anyone help me out on this ? Thanks.
bj33813 is offline   Reply With Quote
Old 03-17-2010, 07:02 PM   #2
DUB
CF Senior Member
First off..there should be a law to stop driver distractions while driving. ENOUGH said on that.
Try buffing it off. test a small spot. It will be hard to say what to use (solvent wise)because you do not know what the make-up or type of paint was that spattered on your 3M bra. If it is a latex based paint and has been allowed to dry...solvents usually will not soften them up. Much like getting latex house paint on a brick and coming back the next day and trying to remove it....very much a pain in the backside.
Do not let your buffer get the 3M stuff to hot.
It (the 3M bra) may be damaged if the solvent in the paint that spattered actually "ate" into the film...and now has become one with it. Try CAREFULLY "picking" at it with a pin....and see if it flakes off or not....trying NOT to dig down into the film.
You could try sanding it off with 2000 grit wet/dry sandpaper and buffing the film out again. Once again...I would do a test in a small spot and see if the film would come back to life IF it did dull out a bit from the sandpaper.
Just some ideas and opinions...free of charge...and may actually be quite worthless.
"DUB"
DUB is offline   Reply With Quote
Old 03-17-2010, 11:05 PM   #3
markids77
CF Senior Member
It did the job and kept the crud off your paint. Why not simply replace it?
markids77 is offline   Reply With Quote
Old 03-25-2010, 07:42 PM   #4
bj33813
CF Senior Member
OK, some success. Wanted to post back what worked for me.
Wash car, put on a good coat of wax (your choice, don't want to start a war) which will help protect the 3M material during spot removal.
I then used a magnifier to get the best possible view, and a NEW single edged razor blade, and very carefully shaved each speck off. Had about 90% success, as some of the larger spots welded right into the film and left a slight pock mark.
I also left a very few scratch marks, but small and not as noticeable as the white specks were, so I call that a success.
Old 03-25-2010, 08:31 PM   #5
DUB
CF Senior Member
Glad that you got it resolved to your expectations.
Smart guy also...it is very easy to start a war on the forum when sometimes giving to much product usage and information....been there and done that before.
"DUB"
Old 04-12-2010, 02:52 PM   #6
VetteBoy1979
CF Senior Member
CI 3-4-8 Veteran
St. Jude Donor '07-'09
VetteBoy1979's Avatar
Send a message via AIM to VetteBoy1979
Typically you can clean it with the strongest ISO Alcohol you can get. That's what 3M recommends, if you can use it.
VetteBoy1979 is offline   Reply With Quote
Reload this Page removing paint spatters from 3M clearbra
Tags
3m, bra, clear, house, paint, removing, taking
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
