03-08-2010, 06:15 PM
CF Senior Member
I seriously doubt that you are going to be able to scrape any more off ...once you get down to the primer/sealer coats. Those will need to be removed....either by chemical stripper, media blasting or sanding it off. I would not recommend sanding it off due to the skilled labor that you are planning on using BETTER know what they are doing VERY WELL when it comes to fiberglass bodies. And goes the same with chemical stripper and or media blasting. I am not a fan of the soda blasting...but that is just me. I do all stripping in house and use chemical stripper....but then again I have been doing it for over 20+ years and know how to use and respect the chemical stripper. I hope that teh shop that you are using knows about the press molded fiberglass. And whatever you do...make sure that you inspect the car BEFORE they apply any product(primer/filler,etc) to the stripped panels...so you can see that it ALL has been removed.
Best of luck,
"DUB"
