Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-02-2010, 07:07 PM   #1
SHAKERATTLEROLL
CF Senior Member
SHAKERATTLEROLL's Avatar
Default Which Harbor Freight HVLP paint gun for SPI Epoxy Primer?
Before anyone gets bent out of shape lol. This gun will only be used for Primer and maybe some small parts for basic black such as the frame and odds and ends.
Thank You for any help.
SHAKERATTLEROLL is offline   Reply With Quote
Old 03-03-2010, 08:31 AM   #2
porchdog
CF Senior Member
porchdog's Avatar
only thing in harbor freight worth carrying out the front door is the cash register.
porchdog is offline   Reply With Quote
Old 03-03-2010, 11:06 AM   #3
markids77
CF Senior Member
Don't have the model number handy at present but my primer gun was purchased from HF for $25.99 recently. I would not spray a complete job with it unless I was forced to, but it lays epoxy down just fine. It is the gun which is anodized dark pink if that helps you shop.
markids77 is offline   Reply With Quote
Old 03-03-2010, 11:44 AM   #4
porchdog
CF Senior Member
porchdog's Avatar
shake, use your iwata .
Old 03-03-2010, 10:34 PM   #5
markids77
CF Senior Member
I bought my first spray guns back in 1974... a Sharpe professional siphon and a Binks model 7 clone for primer. I still own the Sharpe which has never sprayed anything but topcoats, I have owned at least 3 "primer guns" in that time. I can understand fully owning a POS for rough use and preserving the "good" gun. I don't paint for a living anymore... I work in parts now, but I still own a "primer gun" so I don't wear out my primary topcoat weapon.
Old 03-03-2010, 10:37 PM   #6
1snake
CF Senior Member
1snake's Avatar
Quote:
My local HF sells name brand stuff as well as items made in China. Why would you recommend using a top of the line gun to spray primer when a cheap azz gun does just as well? I find it hard to believe ANYONE would use a premium gun for primer. I use a DeVilbiss Finishline for primer and sealer and save my good guns for base & clear.
1snake is offline   Reply With Quote
Old 03-03-2010, 11:02 PM   #7
markids77
CF Senior Member
Carefull, Snake... the Devilbiss IS my finish gun at present!!! I do maybe one or two overalls a year for friends and family, a couple of bikes perhaps. I don't need an Iwata or Sata to turn out decent jobs at a trickle. They might make it easier, but I'm just a broke azz parts pusher by trade... not even a proper booth to work in anymore. BUT... my stuff looks NICE because I care, and take my time on all aspects of the job.
Old 03-04-2010, 08:37 AM   #8
porchdog
CF Senior Member
porchdog's Avatar
i use my iwata lph400 to shoot everything. i spray epoxy just like i spray clear. my guns are as clean today as they were when i bought them . most of these guys are novice painters with little to no gun control. using a cheap pos gun is not going to help them get any. my advice has always been spend the money you are saving on a decent gun and use it for everything. by the time you are ready to shoot clear you will have some control over the gun. plus a good gun you can sell if you choose and recoup most of your money.
snake, i am a professional painter. have been since 72 . in looking back at your post you seem to just want to start one pissing match after another. this childish habit of quoting others is rude and argumentative . watching you argue with the man who manufactures spi was all i needed to see or hear from you. barry kives is well respected in the high end world of restoration and has forgotten more than most will ever learn. thanks to your childish behavior i doubt he will return and that is everyone's loss. he has much to offer and gives his time and advice freely.
Old 03-04-2010, 10:28 AM   #9
killer454
CF Senior Member
killer454's Avatar
Send a message via Yahoo to killer454
i bought a harbor freight gun to do mine on primer and all that happened was after about 5 cups of primer started leaking through the seal at the triger.primer would just run down the handle of the gun from the cup.
after that went and bought a 200 gun
bought their inline board sander to after useing it about 3 hours it locked up.i took it apart and found they used alluminum rivits in it and one broke and fell out at one of the pistons.i fixed it by going to the hardware store and buying small bolts and nuts to replace all the rivits.
works really good now.
i bought their da to fell off my work bench and cracked around the top now all it is good for is to blow the sweet off your forehead throught that long crack in the side of it.bought a new one through napa
just my expeiriance with harbor freight
killer454 is offline   Reply With Quote
Old 03-04-2010, 06:52 PM   #10
M_T_0
CF Senior Member
they make reallllllly nice hammers
M_T_0 is offline   Reply With Quote
Old 03-04-2010, 07:26 PM   #11
Scott Marzahl
CF Senior Member
The Iwata LPH400 with a 1.4 lays down SPI epoxy like glass, saves a ton of time on sanding. The only thing I use that POS harbor freight gun for is shooting POR15 then I can throw it away.
Scott Marzahl is offline   Reply With Quote
Old 03-06-2010, 11:02 PM   #12
redvtt
CF Senior Member
redvtt's Avatar
Location: Never interupt your enemy while he is making a mistake -- Napolean Bonaparte Sacramento CA
I use my HF gun for primer, now. I did use it for solid color basecoat, worked fine. The only real problem is no kits to rebuild it.
I don't paint everyday professionally, so it doesn't get that much use. I also have a Sata I use for touchup & clear, it works great.
redvtt is offline   Reply With Quote
Old 03-08-2010, 06:00 PM   #13
maddoggyusa
Junior Member
THE P-DOG IS BACK!!!!
I always wondered if he'd miss us too much to stay away.
maddoggyusa is offline   Reply With Quote
Old 03-08-2010, 06:03 PM   #14
SHAKERATTLEROLL
CF Senior Member
I do not think it is the Miss part but to help others from doing bad things to there car.
Old 03-27-2010, 04:13 PM   #15
AWilson
CF Senior Member
AWilson's Avatar
Default Things are getting exciting!
Quote:
Scott,
I'm finally ready to paint and just ordered a Iwata LPH400 with a 1.4, both silver and orange caps. I plan to use SPI epoxy for sealing and blocking, PPG 68 Lemans Blue base, then SPI clear.
AWilson is offline   Reply With Quote
Old 03-28-2010, 04:47 PM   #16
SHAKERATTLEROLL
CF Senior Member
Good to hear A Wilson Keep up the work and please by all means keep us posted.
Old 03-30-2010, 06:03 PM   #17
Scott Marzahl
CF Senior Member
Alright Al, sounds like you are getting towards the end of your project.
Scott
Old 04-06-2010, 05:53 PM   #18
lushdrunk
CF Senior Member
lushdrunk's Avatar
You can buy a sharpe razor primer gun from northern tool with a 1.7 tip for $179.99 It's a damn good gun for thick primers.
lushdrunk is offline   Reply With Quote
Reload this Page Which Harbor Freight HVLP paint gun for SPI Epoxy Primer?
Tags
car, cheap, clone, devilbiss, epoxy, finishline, forum, freight, gun, harbor, hvlp, paint, primer, reviews, spi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
