Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-27-2010, 02:53 PM   #1
orourke
CF Senior Member
orourke's Avatar
Default Flo-Coating
Is it really worth the effort to Flo-Coat clear? Do you really notice a visual differance?
Marty.
orourke is offline   Reply With Quote
Old 02-27-2010, 11:50 PM   #2
demonx
CF Senior Member
demonx's Avatar
Your paint job is only going to be as good as the effort you put in.
Flo coating (ie: shooting a couple layers, sand then shooting your final layer) will be better than just shooting a few layers of clear and leaving it off the gun as you wont have as much peel. The idea of flow coating is to cut back on the peel in your finished job, but it you're not that flash at spraying then your flo coat wont be that great anyway. Will still be better than if not done.
I myself like to shoot extra layers of clear (between 4-6 all up depending on project) and then wet rub it all back to 2000 then cut & polish. Thats just the way I was taught and I keep doing it that way. I'm not a "professional" painter so this method allows me more freedom and still gets me a brilliant end result. It does waste a lot more clear though as you have to shoot a couple extra layers and rub them back.
It's all personal preference in the end.
demonx is offline   Reply With Quote
Old 02-28-2010, 12:03 AM   #3
markids77
CF Senior Member
I "perfect" all my final coats, whether cleared or not. Why spend the time, effort and materials to demask, sand, clean, remask and reclear just to do it again? If you're not getting a "slick" coat in the booth, add an extra (final) coat after sufficient flash time, then sand that. That way you get chemical instead of mechanical bond in ALL layers of finish... a better way in my estimation.
markids77 is offline   Reply With Quote
Old 02-28-2010, 11:33 AM   #4
orourke
CF Senior Member
orourke's Avatar
Old 03-01-2010, 10:07 AM   #5
porchdog
CF Senior Member
porchdog's Avatar
the purpose of sanding and flow coating is to cut down on thanewave not orange peel or trash. urethane has a tendency to push a wave as you shoot. i do 4 coats then block with 600 then 2 coats. in doing this i have only 2 coats of texture to deal with . makes detailing much easier and the end job a little flatter .
porchdog is offline   Reply With Quote
Old 03-01-2010, 11:25 PM   #6
1snake
CF Senior Member
1snake's Avatar
Quote:
I disagree. The purpose of flow coating is to eliminate the polishing step. A commonly used procedure in most body shops. If you plan on buffing, why would you sand, spray, sand and polish. Just spray the damn clear, sand it and polish it.
1snake is online now   Reply With Quote
Old 03-01-2010, 11:43 PM   #7
jb1002x
Junior Member
Quote:
So you are saying when you sand down with 600 and re-coat, you don't recieve a deeper and flatter finish?
jb1002x is offline   Reply With Quote
Old 03-01-2010, 11:52 PM   #8
1snake
CF Senior Member
1snake's Avatar
Quote:
The purpose of cutting and buffing is to have a perfect surface. Once you cut it, it's as flat as it's going to get. Then you polish it to a beautiful shine. Why would you sand it, re-spray, sand it again and then polish it. Like I said, flow coating is a trick used by body shops to eliminate the polishing step for the average driver.
Old 03-02-2010, 08:16 AM   #9
porchdog
CF Senior Member
porchdog's Avatar
not only do i sand and glamor coat my clear but i do the same with color.
Reload this Page Flo-Coating
Tags
clear, coat, coating, flo, flocoating, flow, paint, peel, sand, urethane, wet
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
